RV.Net Open Roads Forum: Tech Issues: Inverter
 > Inverter
esfd243
East Syracuse, NY
Posted: 06/04/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
In our 5th wheel we have an inverter that allows us to run the fridge while driving. It also runs the fridge and 1 outlet next to it when the power is out.
Can I leave this on full time to cover for a power outage when we are not in the camper? Or does it need to stay off while not in use?
Mike, Dawn & Mallori
2016 Hemisphere 368RLBH
2012 Chevy 2500 HD D/A 3.73
jdc1
Rescue, Ca
Posted: 06/04/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
That depends on where your power source is. If it's just a battery, it won't last long. If it's plugged in, it'll be fine.
2oldman
NM
Posted: 06/04/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Depends on how it was wired.
2manytoyz
Central FL
Posted: 06/04/20 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Our Class A has 4 house batteries, and a separate battery for the chassis.
I used to only run the inverter while driving. Now I leave it on anytime the residential fridge is running. This way the power doesn't bump on/off when running on the generator, or shore power.
Furthermore, with this pandemic, I'm using the fridge to store additional food while it is parked next to the house. Even though it's connected to shore power, the inverter stays on in case the grid power goes down. The inverter doesn't care.
The inverter in the RV is a Xantrex Prowatt SW2000 model. Same one I have at home, used with my solar setup. This one has been running 24/7/365 since 2011, and powers my office, and workshop. I replaced the GFCI once, but no other issues. This is why I have no concerns about leaving the one in the RV powered when needed.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
BFL13
Victoria, BC
Posted: 06/04/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
You can run the fridge from the inverter, which is supplied by the battery when there is no shore power, but when there is shore power, the inverter runs from the battery which in turn is "supported" by the converter. However, when the "power is out", no converter, so as stated above, it won't last long on just the battery. Some solar can extend that battery time.
It is ok to leave it on the inverter with shore power and converter support. Just hope the power comes back on soon. (Don't leave anything on in that one outlet though, or it will shorten in the battery time even more.)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 06/04/20 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Yes the inverter can run 24/7/365 and will operate perfectly as long as the batteries have enough voltage.
675w Solar pictures back up
Wherever I happen to park
Posted: 06/04/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
An RV Fridge can draw around 3 amps AC or 30 DC when running. that's a lot of current. A GC-2 pair only has about 220 amp hours total 110 that you can use so that's 3 hours (less actually) per pair.
A Residential fridge is often a bit more efficient. figure 4-5 hours max and the Inverter may not let you run it down that far.
Also if the Fridge compressor is RUNNING when shore power is lost (Residential type) that ... May not be good depending on just how fast the inverter's transfer switch flips.. YOu can weld the switch.
Home is where I park it.
pianotuna
Regina, SK, Canada
Posted: 06/04/20 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
The residential fridge at my condo uses less than 2 kwh per day.
Regards, Don
theoldwizard1
SE MI
Posted: 06/04/20 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
What you really want is an inverter/charger/automatic transfer switch !
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 06/07/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Holy Mole Piano Tuna,
I run an entire 1 bdrm apartment on 146 kWh for 63 days. I put a tiny 82mm fan behind the monster 20CF refrigerator to expel the heated air and run time dropped by 35%. No washing machine and all 120VAC lighting. I forgot but the fan draws something like 3 watts. Dual ball bearings.
 > Inverter
