RV.Net Open Roads Forum: Class C Motorhomes: Brake fluid flush
 > Brake fluid flush
classctioga73
west coast
Posted: 06/05/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Anyone have any videos tutorials or websites that show how to do brake fluid flush on a 2000 Ford e- 450 super duty triton V 10 engine. Please help
fourthclassC
MA
Posted: 06/05/20 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Howdy, I don't have any tutorials but I can tell ya how I'm gonna do mine on my 2003 Winnie with rear disc brakes. Start by sucking all the fluid out of both sides of the master with a turkey baster or suitible tool or mitivac pump. Replace it with new fluid. with a helper, pump the brake pedal an hold it. Open the right rear caliper bleeder screw (put some pb blaster on all bleeders ahead of time) allow it to come out till it comes out clear. May take a couple times. No pumping while bleeder open. Move to left rear then right front then finally left front. Making sure the master cylinder dosen't run dry. Need to check after each caliper is completed.
Posted: 06/05/20 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Flushing the brake fluid is just bleeding the brakes over and over again until you’ve pulled new fluid through.
Typical brake bleeding procedures apply.
Either pressure bleed or vacuum bleed. Not vehicle specific.
2017 Heartland Torque T29
Charlie D.
E. Texas-Orange
Posted: 06/05/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Make sure you NEVER let the master cylinder goes dry during bleeding.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
carringb
Corvallis, OR
Posted: 06/05/20 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
^This.
Bleeding is just like doing a car. But if you get air in the ABS pump, it's VERY difficult to get out. So I recommend doing this one with a friend!
2014 ORV really big trailer
2015 Ford Focus ST
garyemunson
Reno, Nevada
Posted: 06/05/20 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Once I got one of these, I've never gone back. Fast and sure. The smaller bottle is a "hamster bottle" that sits upside down on the master cylinder to help keep it filled. As noted above you DO NOT want to run the master cylinder dry and get air in the anti-lock system. The bleeder hooks to your air hose and sucks the fluid out of the calipers. Much faster than any other way. The bleeder bottle is translucent so you can see when the fluid starts running clear. Those who regularly flush their brake system when recommended rarely ever have to replace calipers or master cylinder.
https://www.ebay.com/itm/Air-Pneumatic-Vacuum-Auto-Brake-Clutch-Bleeder-Bleeding-Fluid-Change-Tool-Kit/352275642062?epid=11014536723&hash=item520543b6ce:g[emoticon]YcAAOSwv7ldl-gj
Williams AZ area
Posted: 06/05/20 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
X2, Charlie.
theoldwizard1
SE MI
Posted: 06/05/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
There are dozens of videos on bleeding brakes on YouTube.
The day before, spray all brake bleeders with your favorite penetrating fluid. Do this at least twice and again before you start.
Get a piece of vinyl hose that fits snugly on the bleeder screw. Find a small spring clamp to secure it. Get an empty 1/2 liter plastic bottle. Drill a hole in the cap that is a tight fit for the hose. Put an inch or two of brake fluid in the bottom and push the hose through the cap down into this fluid.
Make sure the bottle stays upright and the hose below the level of the fluid AT ALL TIMES. Some people wire the bottle to some part of the vehicle to make sure it stays upright.
Top off the fluid in the master cylinder with fresh DOT 3 fluid. Open the bleeder screw, no more than 1/2 turn. (If you break the bleeder screw, you will be calling a tow truck to haul you to somewhere that can replace a caliper. $$$$ !) Gravity will force the fluid from the master cylinder into your catch bottle. After 5 or 10 minutes, the level in the bottle will be up about 1 or 2 inches. Close the bleeder.
Refill master with fresh DOT 3 fluid and move on to the next bleeder. You might have to do all 4 bleeders twice to get clean fluid out of each bleeder.
time2roll
Posted: 06/05/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Consider a motive products pressure bleeder.
Probably need the 2 or 3 tab ford adapter.
https://www.motiveproducts.com/collections/domestic-bleeder-kits
Get 2 or 3 quarts of Dot 4 and start with the longest run until it runs clear. I recommend Valvoline or Ford fluid.
675w Solar pictures back up
Home Skillet
Pearland Texas
Posted: 06/05/20 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Absolutely, 100% use this flusher.
I have one and did mine by myself.
The Ford fluid is the best, has a very high wet boiling point.
Also, would be a good time to replace the front rubber brake hoses. They tend to delaminate internally, causing the brake calipers to "stick".
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
 > Brake fluid flush
