RV.Net Open Roads Forum: Tow Vehicles: Ok what truck to buy ?
Search only in Tow Vehicles
 > Ok what truck to buy ?
Page of 5
noteven
Turtle Island
Posted: 06/11/20 05:32am Link  |  Print  |  Notify Moderator
EcoBoost 7.3 V8 600HP!
valhalla360
No paticular place.
Posted: 06/11/20 05:37am Link  |  Print  |  Notify Moderator
specta wrote:
valhalla360 wrote:
2oldman wrote:
Ford's making the 7.3 again?
Sort of...but it's a gas 7.3. Probably a bit of marketing off the love of the old diesel 7.3.
The following combination of bore, stroke, combustion chamber design and compression ration enabled Ford to produce the best horse power while keeping the A/F ration as close to stoichiometric as possible.
7.3L just worked out to work the best.
I'm sure it doesn't cause problems but if there was something magical about that combination of design criteria...everyone would be putting out a 7.3L gas engine.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
thomas201
Eastern Panhandle WV
Posted: 06/11/20 05:38am Link  |  Print  |  Notify Moderator
Bionic gave good advice. Buy first on the seat, then price. You really cannot lose with any of the the big 3.
jerem0621
Tennessee
Posted: 06/11/20 05:59am Link  |  Print  |  Notify Moderator
Define “Struggle” please?
If you mean it slows down on hills and you have to get the RPM’s up to maintain speed, you will have to do that with any Gas V8.
Thanks!
Jeremiah
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
Elk_traveler
maryland
Posted: 06/11/20 07:50am Link  |  Print  |  Notify Moderator
kellem wrote:
After several struggles in the mountains I've decided it's time for a new truck.
My old truck has been really good but new trailer is pushing it.
Current truck is 2004 Ram 2500 5.7 Hemi pulling 8K trailer, struggling mightily on the big hills with a bunch of junk in the bed.
I'm going new here but stuck on the 6.4 Dodge or the 7.3 Ford.
I'm a gas mechanic so no diesel please....yeah I know.
6.4 or 7.3 ?
Then you want a Ford, period. Currently have V10 in Class C Motorhome but towed 5th wheel for many years with 7.3 L Ford turbo diesel and crossed the Rockies many times including the Beartooth highway in Montana towing 10K trailer. Climbed every grade on the Beartooth in overdrive never downshift for any reason. Still own the 96' 7.3L truck which is now ledgendiary. Sadly the EPA and the cost to Ford from engine manufacturer international was to much for Ford to keep in market therefore this engine no longer available.
specta
utah
Posted: 06/11/20 08:26am Link  |  Print  |  Notify Moderator
That's why they went with 7.3L and not 7.1 or 6.9 or 7.4 or 7.8.
That's what they try to achieve for every engine regardless of displacement.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
valhalla360
No paticular place.
Posted: 06/11/20 03:31pm Link  |  Print  |  Notify Moderator
Sure they try to achieve the ideal operations but they can do that with just about any displacement.
If they had a much loved 7.2L, you can bet they would have reworked it during design to be 7.2L.
noteven
Turtle Island
Posted: 06/11/20 06:14pm Link  |  Print  |  Notify Moderator
Teacher! Teacher! I know I know! It’s a 7.3 because no one would know what a 445.47 cubic inch is?
specta
utah
Posted: 06/12/20 06:07am Link  |  Print  |  Notify Moderator
I guess you're right. It ended up being a 7.3 due to their love of the old cornbinder engine.
I was only going by what the engineers said who designed the new 7.3.
blt2ski
Kirkland, Wa
Posted: 06/12/20 09:49am Link  |  Print  |  Notify Moderator
other than liters, unlike the original 6.9/7.3 v8 idi diesels from ihc, they made great gas versions from those blocks too! that will not happen with todays motors no matter how you slice the cake. even IF ihc could have still made the T444E 7.3 version, which had 2 parts left over from the IDI version. Todays version would need to be different also due to as noted, EPA for both sound and air pollution standards. No different than the current GM 4.3 is not the original block design from the mid 80s, ie a 350 with 2 cyllinders lopped off. That block design ended with the vortec 4.3.
As noted, a good engine builder desinger can make ANY engine size run great. Question becomes, does it meet the end spec needed for what it is being used for!
Marty
Check RV.Net Blogs at: blog.rv.net
Page of 5
