RV.Net Open Roads Forum: Onan generator has power to solenoid but not control board
 > Onan generator has power to solenoid but not control board
jimdmorrison
South Dakota/Iowa
Posted: 06/11/20 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys. I have an onan emerald plus 4000 generator. Was testing my new starter and hooked up the jumper cables to it wrong, frying everything. I have since replaced the starter, solenoid, and control panel.
I’m getting power to the solenoid and just 0.2 volts to jumper 7 on the wiring harness if I disconnect the control board. 11 is supposed to be power in, but there’s no power there. It looks like those cables go through a ground or something first.
Any ideas?
Kpackpackkelley
Bryan tx
Posted: 06/11/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
There should be a fuse on the board. You have 12 v at the solenoid what about coming out of the solenoid while pushing the start button. What solenoid did you buy it has to be the right one ?
jimdmorrison
South Dakota/Iowa
Posted: 06/11/20 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Fuse is good. Solenoid is good. Power isn’t getting to the control board at all so switch doesn’t do anything.
jimdmorrison
South Dakota/Iowa
Posted: 06/11/20 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Could it be the voltage regulator?
Kpackpackkelley
Bryan tx
Posted: 06/12/20 05:35am Link  |  Quote  |  Print  |  Notify Moderator
What’s the full model number
jimdmorrison
South Dakota/Iowa
Posted: 06/12/20 10:44am Link  |  Quote  |  Print  |  Notify Moderator
6.5NHEFA26100M
It's a Onan 4000 4.0 BG E-F/A 26100P from 1998.
Kpackpackkelley
Bryan tx
Posted: 06/12/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Nhe or bge ?
jimdmorrison
South Dakota/Iowa
Posted: 06/12/20 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
BGE
Kpackpackkelley
Bryan tx
Posted: 06/12/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll got out later this afternoon and do some testing on one I have on the bench before I say anything.
I would unhook the starter so it doesn’t spin the motor when pushing the start button and start tracing power from the start solenoid with the start button pushed in and see where it goes and where it stops getting power. Tape the starter Wire up so it doesn’t short to anything. You should be able to hear fuel pump running with the start button pushed in.
jimdmorrison
South Dakota/Iowa
Posted: 06/12/20 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel pump runs if I bypass the control board, but no power is getting to the board.
Thanks!
