RV.Net Open Roads Forum: Tow Vehicles: Duramax won't prime.
Search only in Tow Vehicles
 > Duramax won't prime.
Beaker
Brevard, NC
Posted: 06/12/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
2008 Duramax
Went to start truck, took a second or two longer than usual and only ran for a couple of seconds. Will not prime. Fuel filter changed about 2 months ago but only about 100 miles since then.
Coincidence?
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
KD4UPL
Swoope, VA
Posted: 06/12/20 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Did you tighten the filter down? Is the bleed screw on the filter housing tight?
Is the water drain on the bottom closed tightly?
mtofell1
Oregon
Posted: 06/12/20 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if it's the same as my 06 but are you sure it's a priming problem and not some other fuel delivery thing (or, I suppose "prime" could just mean getting fuel)? You could check by releasing the bleeder screw and pumping like you're priming a new filter - if fuel squirts out right away you know you have fuel that far. If the truck ran fine for 100 miles after the filter change I doubt that's the problem. 100 miles in 2 months you could have bad fuel. Lots of possibilities.
SweetLou
La Quinta, CA USA
Posted: 06/12/20 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
I once had an '87 Ford 6.9 and when I had priming issues, I put an electric fuel pump on it so I didn't have to crank the motor. Got fuel to the pump and off we went.
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Turtle n Peeps
California
Posted: 06/12/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I'd bet $5 that this is your problem.
Easy fix and pretty cheap.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
killerbee
PHOENIX USA, Never hot
Posted: 06/12/20 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
If this happened within an hour of shutting down the motor on a hot day, it is a prime issue. Specifically it is diesel vapor forming in the hot filter and line. Just continue to pump, then try to start. Repeat until all the bubbles are out. This will be easier if you leave the hood up for an hour or 2, but can be done when hot.
Michael, Systems Engineer and Professional DURAMAX Diesel Tuner
Killerbee Performance
Beaker
Brevard, NC
Posted: 06/12/20 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, that what I mean won't prime, cannot get fuel to squirt out.
Ran fine when I shut it off a week ago.
Chinolbz
Lake Havasu City, AZ
Posted: 06/12/20 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
x2 on the filter head failure.
Posted: 06/13/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Primer is known to suck air. Like the videos posted.
One way to prime it without Using the primer Is to pressurize the fuel tank, slightly.
Seal up an air hose to the tank at like 5-10psi. It will prime the system and truck will start. If it doesn’t hold then either the primer or bleeder is sucking air likely.
davisenvy
Franklin, NC
Posted: 06/14/20 04:30am Link  |  Quote  |  Print  |  Notify Moderator
There's an o ring under the primer bulb that goes bad. It won't allow you to prime your fuel and won't let your truck to start. The o ring is $10 at your local auto parts store. Good luck.
2006 GMC Sierra 2500HD SLT,4x4,Crew, Duramax EFI Live
2013 StarCraft Autumn Ridge
