RV.Net Open Roads Forum: Tech Issues: Furnace not working well
 > Furnace not working well
swimmer_spe
Sudbury, Ontario, Canada
Posted: 06/13/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
1975 trailer. Furnace issue, but may be a propane issue?
For the last few years, I haven't had a working fridge. This year I finally do, and it works well. For the last few years, the furnace would always heat the trailer well. This year, not so well. It seemed like the furnace wasn't getting enough fuel.
Why would this be the case? We did not plumb in anything that was not already plumbed in. We simply replaced a non working unit for one that did.
midnightsadie
ohio
Posted: 06/13/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
bad regulator? pinched fuel line? bad fuel?
8ntw8tn
Southeast Iowa & Texas Hill Country
Posted: 06/13/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a bad regulator, as posted above. Or it could be that the regulator just needs to be adjusted. I wasn't aware, until a couple years ago, that the regulator had any adjustment to it. But when our furnace refused to keep running I called the repair guy and that's what he diagnosed. A minor adjustment and all was well. Hope this helps.
'08 Chevy Silverado 3500 Duramax;
'10 Carriage Cameo F35FWS
Det 1 56th SOWg
swimmer_spe
Posted: 06/13/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Makes some sense... Is this something I can do? The trailer is a seasonal site in the bush about an hour from a repair shop.
Wherever I happen to park
Posted: 06/13/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Furnace not getting enought fuel but fridge works (I assume on propane) Water heater and stove as well. Ok suspect list
1: Propane tank may have what is called an Excess Flow Valve. This would likely NOT bother Fridge (though one poster said it did) but would water heater and for sure would the furnace if it's closed. If that is the case close tank valve. Pause for oh. about 1 cup of coffee. then SLOWLY open the valve till you just hear gas start to flow.. pause till you don't hear any more flow. Repeat till valve fully open.
Next is the orifice (The small hole from which stuff spews forth, Gas in this case) there is a spider that loves to nest there.. Clean it out.
Next is the spark gap on the Direct Spark Ignightor Make sure it's set per the manual
The Thermocouple normally lasts forever.. but the key word is Normally
The control board may fry. Mine did. I think I know why.. I replaced it with a Dinosaur board replacement and .... It appears they have the same theory as on the Dino board is a device designed to prevent what I think happened.
The solenoid valve can also have issues.
That about covers most of the more common issues. There are a few "Exotic" ones too but those are the most common.
Oh and the Sail switch..
To make sure it does not overheat there is a "Sail Switch" when the T-Stat calls for heat the control board starts the blower (I occasionally have an issue there and I have a detector installed for when it happnes) when the blower is blowing enough air the sail switch sails closed and heat is then generated.
Low battery
Aging blower
Clogged ductwork/vents
Can prevent sail switch from sailing.
Home is where I park it.
John Wayne
Long Beach, Ca
Posted: 06/13/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Go to You tube learn how to make a manometer, and measure and make adjustments to the propane system, and test the system for leaks. Not rocket science and after a few videos you will be able to figure it out.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
enblethen
Moses Lake, WA
Posted: 06/13/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Not worth the dollars for a manometer. Regulators are inexpensive
Dual tank auto switch over
single tank vertical
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
swimmer_spe
Posted: 06/13/20 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Low battery
Aging blower
Water heater is not used. Stove may be fine, but couldn't really tell. same with fridge. It did keep things cold.
The furnace I have is from 1975, so, no circuit boards, ducting or much else. Propane tank is old, but had a new valve installed 6 years ago.
enblethen
Moses Lake, WA
Posted: 06/13/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of the furnace?
swimmer_spe
Posted: 06/13/20 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Duotherm. I might have the manual on it here. I'll go digging.
