RV.Net Open Roads Forum: General RVing Issues: Storing with blank tanks 1/4 full???
 > Storing with blank tanks 1/4 full???
Ron3rd
Upland, CA USA
Posted: 06/14/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Won't hurt anything but I would add more water. Or buy yourself a Sewer Solution and dump at home anytime you want. That's what I do
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
valhalla360
No paticular place.
Posted: 06/14/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Because if it dries to the bottom of the tank it won't be pretty. He wants to store it for months.
Unless his black tank valve has a slow leak...no it won't dry out in TWO WEEKS.
To the OP: Absolutely nothing needs to be done. With a 1/4 tank, it will slosh around on the drive to the new campground, maybe dump on the way in but really, it will continue to break down like in your septic tank over the 2 weeks.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Bob/Olallawa
Kitsap Co, WA/Bullhead City AZ
Posted: 06/14/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Only problem I can think of is poor installation of the tank. If it can't handle the extra weight you might end up having a problem. More so with more weight but it could happen with just 1/4 tank.
Welcome to my home, that door you just broke down was there for your protection not mine.
Veebyes
Posted: 06/14/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
2 weeks, don't sweat it. Add at least a few gallons of water & an extra dose of treatment if that makes you feel better then dump at your first convenient opportunity on the next trip.
2007 Alpenlite 34RLR
512Climber
New York
Posted: 06/14/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone for the helpful suggestions. To answer a few questions in the thread...
The campground we were at didn't have a dup station. They drive around a mini backhoe with a waste tank trailered to pump out waste they only pump on weekdays and we left on a Sunday.... hence 2.5 days with of poop accumulated. My son literally lit it up as soon as the dump truck pulled away.
As for a sewer hookup in my yard... unfortunately it's not an option in my town.
I like the idea of dumping in my home toilet. I'm going to look into that option.
Thanks to everyone for the help and suggestions.
spoon059
Just north of D.C.
Posted: 06/14/20 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
He said two weeks, not months. OP, you'll be fine. If everything works correctly (your tank vents aren't blocked, you have a water seal on your toilet) you won't have any problems.
RV.net people are fanatically searching for a problem for which they can complain...
2015 Ram CTD
2015 Jayco 29QBS
CavemanCharlie
Storden,MN
Posted: 06/15/20 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, as long as you keep water in there so it doesn't dry out you will be fine.
Are you sure there is no where to dump closer to you then a 2 hour drive ??? I'm not from your area but, most of the small towns near me have a dump station some were. Though It might be behind a building or something and sometimes they charge you 5 or 10 bucks. Maybe call a few municipalities near you and ask.
512Climber
New York
Posted: 06/15/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Nearest to me is a little over an hour. So two hour round trip. Its not awful just would rather wait until the next trip if I can.
I've been adding a gallon of water a night through the toilet. Should be good and watered down by the time i get to jellystone.
Ron3rd
Upland, CA USA
Posted: 06/18/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Sewer Solution allows you to dump into any sewer clean out using a 3/4" hose. Research it on YouTube for more information. Not a fast way to dump but works great at home when You're in no hurry
Wishbone51
End of the Oregon Trail
Posted: 06/30/20 02:27am Link  |  Quote  |  Print  |  Notify Moderator
Mine once sat for 3 years with a tank half full. Every once in awhile, I would check the water level to make sure it wasn't drying out.
When I had the trailer repaired and dumped the tanks, it dumped just fine. No smells.
What really surprised me was that the sensors were operating normally.
* This post was edited 06/30/20 11:32am by Wishbone51 *
2017 Jayco Jay Feather 25BH
2004 Nissan Titan
