RV.Net Open Roads Forum: Towing or packing a Smart Car on the back of a Class A
Search only in Dinghy Towing
 > Towing or packing a Smart Car on the back of a Class A
rgatijnet1
Posted: 06/20/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
With the 1800 lbs. weight on the rear axle it may shift enough weight off of the front axle to make the coach wander while going down the road. I would go with a dolly or trailer.
JRscooby
Indepmo
Posted: 06/21/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
It's air suspension and the tag is adjustable. Possibly with the tag set to 10,000 lbs it could make up the difference of the steel structure and car weight located about 13' behind the tag. Right now I can't quickly get my head around the lever arm math.
Even though the suspension can be raised 6" with modification that would be an very poor choice for traveling but works well for air leveling.
Don't know much about MH, but a lifetime of messing with trucks I always found a rougher ride when some axles maxed out, while others where unloaded.
CA Traveler
The Western States
Posted: 06/21/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Not the greatest design for my unit. Front axle is maxed at just under 14K, back axle is maxed at just under 20K. I wanted to increase the 5K tag and reduce the drive weight but can't with the front maxed. And if I emptied the cargo it wouldn't help much.
I suspect that the stability and safety of a RV is compromised with a car on the back. Probably is fine for normal traffic.
But my red line is liability: In case of a major issue my fault or not I don't want to be standing in front of a judge explaining why my RV doesn't meet his state requirements. Also why I recommend aux brakes on a toad.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 06/21/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I have no experience of changing the suspension the air pressure. However the ride is better than any non air suspension RV I've been in, don't know about Class B types. It's also better than any pickup truck I've been in towing or not. Plus with the rear engine significantly quieter to drive.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/22/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
That’s 1800 lbs off the rear, on 3 DPs over 120+K miles. Takes 700 lbs off the front axle
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
rhagfo
Portland, OR
Posted: 06/22/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could trade your current Class A for one like this. The owner stated that it would also take a Smart Car.
fernandolegend
Grand Rapids
Posted: 06/16/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone! Would anyone know where I could find and purchase one of these smart car haulers?
Ivylog
Posted: 06/17/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Congrats on finding this thread for your first post and posting a picture.
You do have a tag axle coach… with only one post it’s hard to tell.
1600 lbs that far back is going to put 2100 lbs on the rear axles and take 700 off the front.
A Smart car is 106” long, 4” over the max legal width…hard to solve this issue.
A modified Hydra Lift is the only one I would use and hopefully I’d not have to get a over width permit for every state I’m in.
I would do a modified wheel lift that doesn’t raise and lower… I drive the car up. Fairly easy to back it up.
tarnold
georgia
Posted: 06/18/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I tow a smart with a self installed elite ll. Look at aluma for a single axle trailer for a smart. But then you have to find a place for the aluma.
Alan_Hepburn
San Jose, Ca, USA
Posted: 06/18/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
It's only been mentioned once here, but be aware that the smart cars from 2008 forward are 4" longer than the maximum allowable width of vehicles. The older, grey-market smarts were shorter and that's why some people got away with loading them cross-ways on the back of their tow vehicles.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
