RV.Net Open Roads Forum: General RVing Issues: Best Wheel Chocks
 > Best Wheel Chocks
Armand_C
Westwood, Northern California
Posted: 06/14/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
So today while trying to get our new fifth wheel ready and loading up our gear into the new trailer, I noticed that the gap between the wheels was considerably wider than our old trailer. I took out our rotochocks and verified that indeed they were not wide enough to fit between the wheels. (i guess that's another item that I'm going to give to the new owners of our old trailer). While looking in to purchase a new set of rotochocks, I discovered that I couldn't find them online anywhere. In fact, they don't even appear when entering the name in the search engine. The closest thing i have found, is the BAL wheel stabilizer. Just wondering what the best chock is out there on the market or what most people are using? Sad to see rotochock go away, I really liked them and were easy to use.
2021 Grand Design Reflection
MitchF150
Puyallup, WA
Posted: 06/14/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
I use a big rock at home.. No, really... It's wedge shaped, big, heavy.. I pull it out of the way, and I use it as a guide when I'm backing the trailer in when I park it. I know to keep about 2' away from it and I know I'm good.
Roll it into place and set it with my foot.. [emoticon]
On the road, I just use some home made 4x4 wedges and a rotochock setup.. Since yours does not fit anymore, maybe rig up some sort of spacer for it between the wheels?
Good luck! Mitch
Mono Basin National Forest Scenic Area
Posted: 06/14/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I like a Harbor Freight’s hard rubber, heavy chocks. $4.99 on special.
fj12ryder
Platte City, MO
Posted: 06/14/20 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
What size RotoChoks do you need? I have some that no longer fit my new trailer. PM me if you're interested.
I also have a set of chocks from Harbor Freight, the rubber ones, and they work very well when I don't wish to use the RotoChoks.
Howard and Peggy
"Don't Panic"
time2roll
Posted: 06/14/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
What size wedges do you have on your rotos? What do you think you need?
I have an extra set that is 5" / 7" width.
675w Solar pictures back up
Veebyes
Posted: 06/14/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Got some decent HD chocks at Harbour Freight. Tossed the plastic junk.
2007 Alpenlite 34RLR
Armand_C
Posted: 06/14/20 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
That is the size that I currently have, and they turned out to be too narrow for the new trailer [emoticon]
jdc1
Rescue, Ca
Posted: 06/15/20 01:08am Link  |  Quote  |  Print  |  Notify Moderator
Those mechanical wheel chocks are a lawsuit waiting to happen. Use a rock or wood chocks.
craig7h
Branson MO area
Posted: 06/15/20 02:34am Link  |  Quote  |  Print  |  Notify Moderator
When I had my 5th Wheel I used the B&L chocks that go between the wheels. I never had a problem with them.
Itasca Meridian SE 36g
Road Master Tow Dolly
bucky
Raleigh metro
Posted: 06/15/20 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Get rubber, they won't slide on concrete or asphalt like the plastic ones do.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
 > Best Wheel Chocks
