RV.Net Open Roads Forum: Fifth-Wheels: Wheel Bearing Repack
 > Wheel Bearing Repack
Page of 8
cummins2014
Utah
Posted: 06/29/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
Ah, so you pulled the bearing apart before you ever traveled and found that the inner race was bad. That would be the only way you could determine that the race was bad from the factory. Yes, it could have been caused by what you described, or it could have been caused by something else. Unless you saw it new and unused, it's just speculation.
I agree , and always blaming it on quality is getting a bit redundant IMO, it’s like always blaming the tire blowout on quality , I’ve seen how people take care of them
fj12ryder
Platte City, MO
Posted: 06/29/20 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
The remaining ridge is still quite visible and I am showing the remaining height. I have been in the tool & die business for more than half a century and understand how things are made. If you cannot or will not accept what I have presented, fine. I still have a customer that his entire business is bearing failure, preventive maintenance and lubrication analysis, he is in total agreement with my conclusion. Perhaps you have more expertise than the both of us.
As I said, you could be correct, based on the available evidence. But I've worked around bearings and machined surfaces also for 40 years, and I've seen bearings fail and look just like that. Since I had put the bearings together, I knew they were good from the box. I don't know that I have more expertise, but I know that after the fact analysis doesn't always result in the correct answer. Just the way things go.
We'll just have to agree to disagree.
Howard and Peggy
"Don't Panic"
Lynnmor
Red Lion
Posted: 06/29/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
This bearing is from the same batch with the same small amount of usage:
Mike134
Elgin
Posted: 06/29/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
When I saw the Brown and Sharpe Dial gauge I knew you were no weekend Harbor fright tool warrior. Still have my Dad's B&S micrometers and calipers must be 50/60 years old.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
phillyg
SWFL
Posted: 06/29/20 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Now boys (and maybe girls), my original post was only to determine if the price quoted for repacking was fair. It doesn't need to devolve into disagreements about the quality of bearings, lack of quality control, or technical expertise, etc.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Lynnmor
Red Lion
Posted: 06/29/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
If the mechanic thoroughly cleans and looks for all those things that I presented and does a professional job, the price may be fair. If he works like many on YouTube videos and others that deny that quality may be a problem, then free is too much. Good Luck.
phillyg
SWFL
Posted: 06/29/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Already got the FW back after they told me $2,300 to replace all four backing plates, etc.
Cummins12V98
on the road
Posted: 06/30/20 08:31am Link  |  Quote  |  Print  |  Notify Moderator
"I replaced all bearings with MADE IN USA Timkens, I'm done with bearings from a country with no moral compass."
GOOD Man!!! YES they ARE US Made. Some simply keep trying to justify buying "Com$%^&*T CHINESE" products when US Made are readily available.
Notice I didn't completely spell out THAT "OFFENSIVE" to some word! I didn't want my post deleted!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 06/30/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
That price could have bought you a Disk conversion kit.
FYI posts DO change direction.
Page of 8
