RV.Net Open Roads Forum: General RVing Issues: Time to restring day/night window shades
 > Time to restring day/night window shades
boston blacky
Gatineau Quebec Canada
Posted: 06/16/20 06:06am Link  |  Quote  |  Print  |  Notify Moderator
We are unable to find our old diagram drawings showing exactly how to restring our day/night rv blinds. Seems I once ordered a kit - from (I can not recall where) which also came with a plan drawing explaining where to string the cords and where they cris-cross, etc. Please let me know if you can help me track down that address. BB[emoticon]
BOSTON BLK
Dick_B
Palos Heights, IL USA
Posted: 06/16/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
or better yet replace them with cleanable mini blinds.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
DrewE
Vermont
Posted: 06/16/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
On mine, there are four strings. The two leftmost ones form a loop, going down from the top, across to the right side within the bottom slider bit, and from the right edge of the slider down and looped around the righthand button thingy on the wall at the very bottom. The ones that start on the right at the top of course are routed similarly, but mirrored left to right, so the cords all cross in the middle of the bottom slider. That, of course, is what keeps the slider more or less horizontal all the time.
Cummins12V98
on the road
Posted: 06/16/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Replace with MCD pull down shades.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ryoung
Oregon
Posted: 06/16/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Here is a You Tube video that might help.
ryoung
2018 Ram 3500 SRW Diesel
2019 Wolf Creek 840
ajriding
st clair
Posted: 06/16/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes, they cross over. Left ones go down and exit right...
The tension on the string keeps it from moving. You tie it at the bottom of the window frame to that post and that tension is key to it all working of course
Mini blinds are terrible for a camper. Worst thing I ever did was install mini blinds. I had to sell the camper it was so bad...
Gjac
Milford, CT
Posted: 06/20/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
When my first one broke on a trip in 2006 I just retied the broken string and all is still well. When my second one broke several years later I realized that there is a grommet that’s the string slides through that sometimes shifts out of place and causes the string to fray. I restrung that one after I fixed the grommet using waxed nylon cord and it slides up and down much easier. I just used the one on the left side as reference.
F1bNorm
Gardena, CA
Posted: 06/20/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
There are utube vids and web sites that describe the restringing. This is the one I used: https://winnebagoind.com/resources/service/pdfs/2006-09%20Restringing%20Day%20Night%20Blinds.pdf
A restring kit also has instructions, but if you can locate the the correct weight fishing line or buy just the line, its much cheaper.
Some tips: using thin CA ( Krazy) glue, Glue the grommets in place. As someone else mentioned, the reason the string breaks is because the grommet is out of place and the string is rubbing on bare metal. Second, when threading the string, harden the first couple inches with the CA glue. Makes the string stiff and easy to thread, cut off when finished.
F1BNorm
garyhaupt
Penticton, BC..land of wine, sun, retirees....
Posted: 06/21/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I so wish I hadn't read this thread..because we all know what happens now....
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
TechWriter
On The Road
Posted: 06/21/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Don't even. That's what I did and several of my MCDs, which are wildly expensive, have failed. I have to use a clamp to keep one of my MCDs from rolling up.
Wished I had kept my original shades.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
