RV.Net Open Roads Forum: Truck Campers: 19.5s again ... new recommendations?
 > 19.5s again ... new recommendations?
jimh425
Western MT
Posted: 06/17/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
I’m one of those who are running 19.5s. Anyone have any new recommendations for their camper haulers that are running 19.5s? I have a DRW, but I don’t think that is the major difference. I think Steer vs Drive is the potential issue.
I’m thinking of maybe continuing to have different tires on front compared to rear. I’d like to stay with M+S on both axles, but the front doesn’t have to be as aggressive.
S Davis
Western WA
Posted: 06/17/20 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I went with Toyo M608 on my 2013 2500HD, they worked well except a little noisy with the open shoulder on the front . I run around 10,500lbs loaded and got almost 65,000 miles and still had tread left, I upgraded my truck to a 2019 otherwise they would still be on the truck. They were real good in the rain and had excellent traction in the snow and ice.
ISBRAM
Denver, Colorado
Posted: 06/17/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
If the truck has 4x4 the steer axle is a drive axle and should have the same tread pattern as the rear axle. I run M&S type 19.5 tire but it has closed shoulder ribs I think it's less prone to cupping and maybe a little less noisy a highway speeds.
1999 Dodge Ram 2500 QC LB Cummins
2013 Airstream International 25FB
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
Oregun
Oregon
Posted: 06/17/20 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
How did the Hankook tires do for you?
I run the Cooper RM253 tires all around on mine. They seem fine to me but
I don't have a lot of miles on them.
Buzzcut1
Norcal
Posted: 06/17/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Ran the same tire on my SRW worked great in all conditions. My buddy now has that truck and tire set up under his Lance 950. He has had it in mud, dirt, snow, stream crossings, and highway with no complaints. the tires wear really well.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
jimh425
Western MT
Posted: 06/17/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, the Hankooks were fine, but the same model isn’t available any more.
srschang
Western NY
Posted: 06/19/20 07:06am Link  |  Quote  |  Print  |  Notify Moderator
I have the Cooper RM352 19.5's on my Ram as well. A bit noisy as expected with the aggressive tread, I'm OK with it. The only problem is I can't get two of the four balanced. I've tried two different tire shops, and they stack weights on top of each other as they are that far out of balance. Still shake at 37-44 mph and 67 and up mph.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
