RV.Net Open Roads Forum: Fifth-Wheels: 5.9 Cummins Diesel Towing capacity
 > 5.9 Cummins Diesel Towing capacity
Second Chance
Wherever...
Posted: 06/18/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Allworth wrote:
You probably don't have the rear axle capacity to carry that pin weight, even with a dually (2001).
The engine will handle it fine. Maybe not at 70mph, but at any reasonable speed.
He says he has a dual rear wheel truck. Why do you think he doesn't have the payload for a 15K fiver (3,500 lbs. pin weight)?
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Durb
NW
Posted: 06/18/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
That truck with a 3.55 rear axle has a gross combined weight rating of 20,000#, with a 4.10 axle 21,000#. The empty truck weighs 6,700# if 2WD, 7,000# if 4WD. Toss in a couple of passengers and a hitch, maybe 700#. This leaves you with an "in spec" trailer weight of 12,300# to 13,600#. The truck may do it but I think it would be poor advice to tell you to go for it. You will see a bunch of anecdotal advice telling you otherwise and contrary to the manufacturer's numbers.
fj12ryder
Platte City, MO
Posted: 06/18/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I kind of agree with most of what you're saying, but I just don't think it's as black and white. If you increase the HP and change the gear ratio, can you pull more load than what the GVCWR says you can? If not, why not?
I pull more weight than what is stated as my GCVWR, but I've increased the HP, and I'm right at my GVWR, and under my RAWR. Personally I'm more concerned with the GVWR and RAWR than the combined weight rating. The truck and trailer goes, stops, and handles with no issues. I wouldn't want to haul much more than what I have, unlike hotshotters, but I don't have an issue with what I am hauling.
Howard and Peggy
"Don't Panic"
rhagfo
Portland, OR
Posted: 06/18/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
The Cummins will have no issues towing that kind of weight however the weak link is the 47RE auto tranny. The 47RE can be rebuilt to stand up to heavy towing duties. Now if the tranny is the 5 speed manual NV4500 or the 6 speed manual NV5600 then no problems.
You have the truck so like all truckers drop by a set of scales and get the trucks front and rear separate empty axle weights. That way you know how much payload the truck can carry.
On my 2001 all the door tag had was GVWR....FAWR...RAWR numbers. No payload numbers on the older trucks....eliminates confusion.
I agree that the trans is the weak link. We towed a 5er at about 13,000# with a 2001 Ram 2500 small chip and exhaust brake.
Durb
NW
Posted: 06/18/20 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Let's see.....
We'll comply with the rear axle rating. The axle manufacturer knows what they are doing.
We'll comply with the tire loading specs, those guys have their act together.
We'll comply with the GVWR, Dodge knows what they are doing.
The gross combined vehicle rating is idiocy and we will just ignore that one.
Who decides which ratings to ignore and which to follow? Does chipping an engine improve the cooling capacity, shock damping, frame strength or any of a number of other factors Dodge considered when designing the truck and assigning capacity numbers? I choose to stay within the factory specs.
rhagfo
Portland, OR
Posted: 06/18/20 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
Durb wrote:
Let's see.....
Well Dana the axle manufacture rated the Dana 80 at around 10,000#
I believe the tires on a 2001 Ram DRW were 17" rated at 3,042# each so 12,168# of tire capacity.
Well the 2001 Ram 3500 DRW had a GVWR of 11,500#, so should be within that spec.
This is a power and gear ratio rating, comfort of towing.
I towed a 32' 5er with a 2001 Ram 2500 Camper Special GVWR 8,800#. That 5er grew from about 11,800# to at last scaling 13,600#, last time I towed it with the 2500 it likely weighed in at 13,000# with a 2,700# pin. I was over GVWR by about 1,700# considering the 3.55's I was over GCWR of 16,000# by about 4,500#, still pulled hills at the speed limit (small chip and RV275 injectors) I also has an PacBrake.
NOT something I encourage others to do, but worked fine for me for six years. We now tow the same trailer with a 2016 Ram 3500 DRW 6.7 CTD and 3.73's, power wise far better, handling much also better, but the old TV never scared me.
noteven
Turtle Island
Posted: 06/19/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
You guys know those Kenworth trucks you see pulling a yuge construction machine, drilling rig or transformer aren’t door sticker rated for 348,000 lbs GCW right?
Durb
NW
Posted: 06/19/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
We know nothing about the OP's truck except it is chipped and the transmission is rebuilt. What if it is heavily optioned which adds weight? What if it has an aftermarket front bumper with winch or heavy running boards? What if he has an auxiliary fuel tank in the bed or he has a penchant for taking firewood. Worse yet, what if he is hauling precious cargo; namely 3 children in the back seat?
I don't think it is prudent to recommend someone to overload their truck by possibly up to 3,000 pounds because they have done so in the past. I won't do it. The OP should consider a lighter trailer.
fj12ryder
Platte City, MO
Posted: 06/19/20 11:33am Link  |  Quote  |  Print  |  Notify Moderator
You should definitely do what you feel is safe.
Cummins12V98
on the road
Posted: 06/19/20 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I know bags technically don’t add capacity. BUT as an example my 15 RAM only has two thin full leaf springs with two short ones to control axle wrap. My rear axle weight is at least 9,750# with 6k pin. Truck is rock solid.
So take it for what it’s worth!
2000-2002 it’s easy to upgrade to 2003-2009 3rd gen front brakes. Insane braking difference!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
