RV.Net Open Roads Forum: Class A Motorhomes: 2000 Bounder Electrical Problem
 > 2000 Bounder Electrical Problem
TCmart
Long Island, NY
Posted: 06/18/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Hi all. Just returned from a 1500 mile trip to Florida. My Fleetwood Bounder with the V10 engine started to turn off abruptly whenever I hit a bump in the roadway. Sometimes it would restart on its own and other times I had to shift into neutral while rolling along at 55 mph and restart it with the key.
It started every time but it was more than nerve wracking.
I checked all battery connections, cleaned, tightened and even ran another ground wire to the engine block.
I then replaced the ignition switch in the steering column.
The problem persists.
Any experience with this problem or any tips on where to look next would be appreciated.
Thanks.
Tom and Christine
2000 Bounder 34T
Life is Good!
enblethen
Moses Lake, WA
Posted: 06/18/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
It takes battery power to run. My guess would be to start at the chassis battery disconnect for loose connections.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jdc1
Rescue, Ca
Posted: 06/18/20 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Since you DON'T need a battery to keep a vehicle running (the alternator will do that), it has to be an ignition problem. When I say "ignition" I don't mean the starter or key section. Look at how an older vehicle operates. The coil and distributor provide the electricity to the plugs (in your case, coils). I'm far from being an automotive guru, but, I would think your problem lies in the ignition distribution......maybe even a computer connection.
* This post was edited 06/18/20 03:14pm by jdc1 *
midnightsadie
ohio
Posted: 06/18/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
take the ground wire OFF the frame clean to bare metal and reinstall. ground problems are the cause off 99% of electrical troubles.
allbrandauto
maryland
Posted: 06/18/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
with it running take the key and jiggle it a little to the off position and see if it cuts off
garry1p
Oklahoma
Posted: 06/18/20 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Well you have done all the normal things time to consider where is 12vDC mandatory to keep the engine running?
Majority of electrical problems turn out th be a bad ground.
Time to start jerking on wires and thumping fuses with the engine running.
Solenoids
Fuel pump
Distributor
Computer
Good luck and post back what you find.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Lt46
Central Florida
Posted: 06/18/20 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Check the inertia switch's red button, make sure it is completely depressed.The inertia switch is on the floor/firewall behind or near the brake pedal. In a collision/rollover it is supposed to kill power to the fuel pump.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
TCmart
Long Island, NY
Posted: 06/18/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestions. A good friend is a truck mechanic and he said he would take a look at it. His suggestion was to pull wires and shake relays to see if we can replicate it in the shop.
I'll let you know if we're successful.
TCmart
Long Island, NY
Posted: 06/18/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestions. .i cleaned the ground wire to bare metal and added an additional ground wire to make sure it was a solid connection.
I jiggled the key, the engine kept running.
The red cutoff switch is fully depressed.
I'm moving on to jiggling and thumping!
Bruce Brown
Northern NY
Posted: 06/19/20 04:00am Link  |  Quote  |  Print  |  Notify Moderator
I don't know if its the case with the OPs MH, but some newer vehicles do need a healthy battery to run. Want to ask me how I know? [emoticon]
Given the vintage of the OPs MH, I suspect it might.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
