RV.Net Open Roads Forum: Fifth-Wheels: Bed slide "flange" problems
 > Bed slide "flange" problems
Usnthedog
Lyons, Ks
Posted: 06/21/20 03:48pm Link  |  Print  |  Notify Moderator
The bed slide trim on my Greystone Re32 slide is flexing inward when the slide is out. Just looking at it it looks like the slide is a box and 1/2 plywood flanges were fastened to the box to keep it from falling out of the trailer. This seems to be a normal set up but my main slides seem to have some bracing and this does not. The trim is a 1x6 trim boards with separate corner blocks. The flanges have flexed so much that the blocks have came loose. It is all wrapped in rubber fabric so I can't see much. Does anyone know how this is put together? Is there a brace somewhere that keeps the flange solid or is it just nailed/screwed to the "box"? I'd send pictures if I could figure out how. Thanks, Jeff
It is a Heartland brand. Like a Sundance only Gray. Made only a couple of years.
* This post was edited 06/24/20 08:48am by Usnthedog *
humblerb
houston
Posted: 06/23/20 07:07am Link  |  Print  |  Notify Moderator
I don't have a lot of experience with trailers, but pictures would probably help a lot, if you can post some.
BarneyS
S.E. Lower Michigan
Posted: 06/23/20 07:39am Link  |  Print  |  Notify Moderator
Jeff,
If you will follow these directions exactly, it is very easy to post pictures on our forums. One of our moderators, 1492, developed this photo posting app to post your pictures. It works for other internet sites also. There is no need to have a separate hosting site for your pictures in order to use it.
It is very simple to use.
1. Upload your picture from your computer to the app.
2. Copy the resulting URL.
3. Paste that URL into your post without ANY changes. No additions or deletions.
Your picture will then appear in your post and be properly sized for use on our forums.[emoticon]
Barney
Not towing now.
Usnthedog
Lyons, Ks
Posted: 06/23/20 08:10am Link  |  Print  |  Notify Moderator
Hope this picture appears.
BarneyS
S.E. Lower Michigan
Posted: 06/23/20 08:13am Link  |  Print  |  Notify Moderator
Yep, it is showing up. That app works great and is very easy to use - as you just found out.[emoticon]
Barney
Huntindog
Phoenix AZ
Posted: 06/23/20 09:31am Link  |  Print  |  Notify Moderator
The slides I have had all had mechanical stops in the mechanisms... They did not rely on the inside trim as yous appears to be doing. Look for such a stop.It should be adjustable.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
Usnthedog
Lyons, Ks
Posted: 06/24/20 08:46am Link  |  Print  |  Notify Moderator
This as far as I know is rack and pinion. As the slide extends it hits the top and then the bottom/sides are pushed out until the pinion slips on the rack with a very noticeable clunk. My main slides are like this and they behave the same.
Huntindog
Phoenix AZ
Posted: 06/24/20 12:31pm Link  |  Print  |  Notify Moderator
How does the pinion "slip" on the rack?
Usnthedog
Lyons, Ks
Posted: 06/25/20 07:02am Link  |  Print  |  Notify Moderator
That is what I think happens. The pinion gear tooth rides up over the rack tooth at the end of travel. I'll accept anyone else's explanation. The point is that the system stops when the slide is fully extended. There could be a built in ratchet that relieves the end of travel stress. It is not motor stall. The noticeable clunk is a giveaway that it is a mechanical separation of the motor and the slide. Am I the only one who has a system like this?
Jeff
Huntindog
Phoenix AZ
Posted: 06/25/20 11:11am Link  |  Print  |  Notify Moderator
Jeff
What I am getting at is that there should be a mechanical stop, and it should be adjustable. It should mechanically stop just as the flange touches the wall. There should little to no pressure on the flange.
As for your slides mechanics... I do not know, There are quite a few different ones out there
