RV.Net Open Roads Forum: Class A Motorhomes: FORD 460 Overheating Mystery
 > FORD 460 Overheating Mystery
Page of 8
MrWizard
Traveling
Posted: 09/12/20 02:58am Link  |  Quote  |  Print  |  Notify Moderator
Are the rubber shrouds/air dams that belong around the the top and sides of the radiator still in place and in good shape
These must be there, they seal the front of the RV and force the air to go thru the radiator and not around or under/over radiator and engine
Your comment about removing the engine cover/doghouse , caused me to think you increased air flow thru the cooling system by allowing it into the RV
Radiate The Happy
1997 F53 Bounder 36s
goprolocal
Gilbert, Arizona
Posted: 09/12/20 11:36am Link  |  Quote  |  Print  |  Notify Moderator
It's further back in the post but the temperature sending unit AND gauge have both been replaced...twice [emoticon]
goprolocal
Gilbert, Arizona
Posted: 09/12/20 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
All the rubber in the engine compartment is intact and directing air through the radiator directly.
Here again is a list of items that have been replaced to diagnose this hot issue.
SYMPTOM:
Rig: 1996-1997 Fleetwood Southwind 35P
Ford 460 engine
I bought it from auction at 23K miles about 5 years ago. I noticed right away that it ran on the hotter side of normal when traveling down the highway at speed over time. This seems to have progressively gotten to be worse over the last 10K miles (rig now has 33K miles on it).
Now, when driving down the freeway with the overdrive off to simulate towing rpm, after about 10-15 minutes at 65mph, the temperature suddenly jumps from 210 to 255 degrees....like within 15 seconds. It will then stay at 255 until we either slow down to city street speeds. If I turn the overdrive on, it will cool to 245 degrees or so.
Driving around town, the rig runs at 210 no problem...even with it being 115 degrees outside here in Arizona. But get on the highway for a bit and she gets hot. The rig has never boiled completely over. It runs excellent, no transmission slipping, engine missing, hard starting, nothing...runs great!
Here is what we've done and tried:
Check for exhaust gases in coolant (nope, not a blown head gasket)
Checked clutch fan blades to be sure they are oriented properly (sucking air from the front to back of the radiator)
Flush block and radiator (some **** came out)
Vacuum filled block and radiator (in case some air pocket?)
Replaced clutch fan (it's oriented correctly and working..I can hear it come on)
Replaced radiator (yes, it's the proper radiator)
Replaced thermostat (3x)
Replaced fuel filter and fuel pump (in case it was running lean)
Replaced spark plugs and wires
Replaced oil and tranny fluid (very small amount of metal shavings in tranny fluid)
Replaced water pump
Replaced radiator hoses (in case it was kinking at high rpm)
It was suggested that possible hot O2 sensors may be causing the rig to run lean under load. Anyone have any insight into this possibility. It has done something like a vapor lock when it was super hot after we pulled off the highway into a gas station...the rig sputtered and died at the pump. I could hear the fuel boiling so I'm pretty sure that was why. After letting it cool for 3 hours, it ran fine again. Just in case, I also opened the fuel cap to rule out a vacuum holding fuel back.
At this point, I don't even know what else to replace or try...maybe an auxiliary electric fan? The other test I think we need to try is a flow test to see that water is circulating properly.
It remains a mystery!
Thank you to everyone for your ideas and input. I don't want to sell this rig but it's looking like that may be the final answer...either that or drive it until it's dead.
Anyone have any input on the long term damage of running it at 255 degrees for 4-6 hour legs?
Brian in Michigan
S.E. Mi.
Posted: 09/12/20 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
How about the sending unit itself? Kind of odd that the temp can jump that quick.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
Brian in Michigan
S.E. Mi.
Posted: 09/12/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
another thing I did with my P-30 chassis was I blocked up any place that air could escape once it got past the front grill. This was so any air that came through the grill had to push through the radiator. I got a 15-20 degree drop in temperature but still ran hot till I got the radiator re cored. What I did was used some 1/4" hardware cloth and stapled it in. Then I used spray foam on the screen. Its been like that for at least a dozen plus years.
John&Joey
Summer-North,Winter-South
Posted: 09/12/20 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
That ford 460 is a flat tappet engine. I'm guessing you could be using the wrong oil in it. What you want is oil with Zinc. I use to run 15w40 Rotella.
Do a Google search on zinc in oil. The new oils don't use it anymore but that old motor requires it. Guessing at high rpms you're creating more friction = heat.
time2roll
Posted: 09/12/20 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
"After six months we finally found out that some idiot had replaced the water pump and threw the steel plate that went between the water pump and the engine block away. The pump could not circulate the water properly. Once replaced the truck runs...and cools... like a top, but it's still a 460. You don't pass many gas stations with this baby!"
https://www.460ford.com/threads/460-overheating-solution-found.154369/
https://www.460ford.com/threads/water-pump-backing-plate.117212/
Possible this was done by prior owner's shop. Verify with your shop if the plate was actually removed and replaced. Apparently not all replacement pumps come with a new plate and apparently some technicians don't think it is needed unless supplied.
This apparently reduces coolant flow. So again back to the flow test.
* This post was edited 09/12/20 03:16pm by time2roll *
675w Solar pictures back up
Stim
NE Florida
Posted: 09/13/20 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just another wild guess, partially stopped up muffler. ???
4x4van
California
Posted: 09/14/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
crawford wrote:
maybe wrong but I believe clutch fans after about 50 mph aren't needed and disengage
Not necessarily. My Workhorse fan clutch kicks in if temps gets to 208 regardless of vehicle speed; it roars when on so there is no doubt, and it immediately drops my temps back to 204 where it shuts back off. Although my last RV was the Ford 460 (carb), and I don't remember the fan clutch making as much of a roar as this GM motor does.
* This post was edited 09/14/20 10:42am by 4x4van *
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
Rocket9k
Akron
Posted: 09/18/20 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
SYMPTOM:
Ford 460 engine
Replaced water pump
Goprolocal, you're in too deep to give up on it now. Sounds like a great unit otherwise. You are in Arizona correct? I have a 1997 Winnebago Adventurer 34RQ that I just went through this with. A 460 is a hot runner, but running any V8 big block at a sustained 255 degrees is never ideal and will shorten engine/trans life. I have a few questions:
-What brand radiator was used? The factory one has been discontinued for sometime, and there are more than a few incorrect radiators advertised as correct radiators.
-Do you have a trans temp gauge? If so, what does it read?
-What brand fan clutch was used (model number if possible?)
If your engine is nearing 230F and the fan clutch is not fully engaged, it is not operating properly. The fan (once running) should be able to pull engine temp down fairly quickly (within 60 seconds). The fans on these chassis are quite aggressive, and when they are singing, capable of cooling the rig down quite well. As with radiators for this chassis, there are more wrong fan clutches than right ones.
If you are not boiling over running it hard in the desert at 110+ degrees you are doing pretty good, just not quite good enough.
Page of 8
