RV.Net Open Roads Forum: Class A Motorhomes: FORD 460 Overheating Mystery
 > FORD 460 Overheating Mystery
Page of 8
goprolocal
Gilbert, Arizona
Posted: 09/18/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Rocket9k wrote:
goprolocal wrote:
All the rubber in the engine compartment is intact and directing air through the radiator directly.
Here again is a list of items that have been replaced to diagnose this hot issue.
SYMPTOM:
Rig: 1996-1997 Fleetwood Southwind 35P
Ford 460 engine
I bought it from auction at 23K miles about 5 years ago. I noticed right away that it ran on the hotter side of normal when traveling down the highway at speed over time. This seems to have progressively gotten to be worse over the last 10K miles (rig now has 33K miles on it).
Now, when driving down the freeway with the overdrive off to simulate towing rpm, after about 10-15 minutes at 65mph, the temperature suddenly jumps from 210 to 255 degrees....like within 15 seconds. It will then stay at 255 until we either slow down to city street speeds. If I turn the overdrive on, it will cool to 245 degrees or so.
Driving around town, the rig runs at 210 no problem...even with it being 115 degrees outside here in Arizona. But get on the highway for a bit and she gets hot. The rig has never boiled completely over. It runs excellent, no transmission slipping, engine missing, hard starting, nothing...runs great!
Here is what we've done and tried:
Check for exhaust gases in coolant (nope, not a blown head gasket)
Checked clutch fan blades to be sure they are oriented properly (sucking air from the front to back of the radiator)
Flush block and radiator (some **** came out)
Vacuum filled block and radiator (in case some air pocket?)
Replaced clutch fan (it's oriented correctly and working..I can hear it come on)
Replaced radiator (yes, it's the proper radiator)
Replaced thermostat (3x)
Replaced fuel filter and fuel pump (in case it was running lean)
Replaced spark plugs and wires
Replaced oil and tranny fluid (very small amount of metal shavings in tranny fluid)
Replaced water pump
Replaced radiator hoses (in case it was kinking at high rpm)
It was suggested that possible hot O2 sensors may be causing the rig to run lean under load. Anyone have any insight into this possibility. It has done something like a vapor lock when it was super hot after we pulled off the highway into a gas station...the rig sputtered and died at the pump. I could hear the fuel boiling so I'm pretty sure that was why. After letting it cool for 3 hours, it ran fine again. Just in case, I also opened the fuel cap to rule out a vacuum holding fuel back.
At this point, I don't even know what else to replace or try...maybe an auxiliary electric fan? The other test I think we need to try is a flow test to see that water is circulating properly.
It remains a mystery!
Thank you to everyone for your ideas and input. I don't want to sell this rig but it's looking like that may be the final answer...either that or drive it until it's dead.
Anyone have any input on the long term damage of running it at 255 degrees for 4-6 hour legs?
Goprolocal, you're in too deep to give up on it now. Sounds like a great unit otherwise. You are in Arizona correct? I have a 1997 Winnebago Adventurer 34RQ that I just went through this with. A 460 is a hot runner, but running any V8 big block at a sustained 255 degrees is never ideal and will shorten engine/trans life. I have a few questions:
-What brand radiator was used? The factory one has been discontinued for sometime, and there are more than a few incorrect radiators advertised as correct radiators.
-Do you have a trans temp gauge? If so, what does it read?
-What brand fan clutch was used (model number if possible?)
If your engine is nearing 230F and the fan clutch is not fully engaged, it is not operating properly. The fan (once running) should be able to pull engine temp down fairly quickly (within 60 seconds). The fans on these chassis are quite aggressive, and when they are singing, capable of cooling the rig down quite well. As with radiators for this chassis, there are more wrong fan clutches than right ones.
If you are not boiling over running it hard in the desert at 110+ degrees you are doing pretty good, just not quite good enough.
I just called the shop that replaced the radiator a few years ago...no answer but I'm hoping they have the info. I can tell you that it was getting hot before the radiator was replaced and there was no change then after the radiator, water pump and thermostat were all replaced at the same time. The hot issue just seems to have progressively gotten worse over time.
I'm going to call the shop and see what fan they put on it...they did make sure the blades were correctly oriented. I'm also going to suggest a coolant flow test of some sort. I don't have a trans temp gouge on the rig. I also plan to completely seal off the front of the rig somehow so that every molecule of air is forced to go through the radiator. We have a trip coming up in a few weeks...Gilbert, Az. to San Diego, Ca. Hopefully it will be a cooler run. [emoticon]
Rocket9k
Akron
Posted: 09/18/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
goprolocal wrote:
SYMPTOM:
Ford 460 engine
Replaced water pump
I am suspicious of you radiator/fan clutch setup. Like it was mentioned before, Radiators for this chassis are not created equal. My money is on the fan clutch. If you are reaching 230f and the fan is not roaring, that's a problem. You can have the healthiest cooling system ever and without a properly functioning fan, it will still run hot/overheat. Fin count in the radiator can affect fan clutch operation as well as was mentioned previously.
goprolocal
Gilbert, Arizona
Posted: 09/18/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
The fan cluth was just replaced a couple weeks ago. I can hear it roaring when it kicks on and it's oriented properly (sucking air from the front of the radiator to the back). And I do see it cool things off temporarily a few degrees when I hear it come on. Over time it heats up though...despite the fan it seems.
time2roll
Posted: 09/18/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I want to know what is behind the water pump.
675w Solar pictures back up
Rocket9k
Akron
Posted: 09/19/20 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
goprolocal wrote:
Hi,
When the fan comes on, what temperature on your gauge do you see it come on? I'm assuming you have the ford NORMAL gauge and an aftermarket numerical gauge. Do you hear it kicking on and off briefly at traffic lights/stops?
alvie h
al.
Posted: 09/19/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Have you had your engine timing checked. To high or to low will make a engine run hot. Just something that will not cost you a arm and leg
patperry2766
Saginaw Texas
Posted: 09/20/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
You're not running straight antifreeze are you? Don't remember seeing this commented on, but I could have missed it.
Courage is the feeling you have right before you fully understand the situation
rgatijnet1
Posted: 09/20/20 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have access to a ScanGauge, or similar type gauge to hook up to your OBDII connection to get an accurate temperature of the coolant?
Do you have one of those inexpensive laser temperature guns to check around your coolant flow path to see where the temperature is being generated. In other words what is the temp of the coolant in to the radiator and the temp out of the radiator.
I believe that your transmission fluid also runs through your engine radiator. Is there any chance that your transmission is running hot, for whatever reason, and this is affecting the engine coolant temp?
goprolocal
Gilbert, Arizona
Posted: 09/21/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Nope, 50/50
goprolocal
Gilbert, Arizona
Posted: 09/21/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I did talk to my transmission shop. They said that if it was caused by the tranny, there would be tranny issues. This rig shifts smooth and perfect. I've used the laser temp but I'm not able to get an accurate reading I trust from parts of the block and radiator.
I'll ask the shop if they've hooked up the obdii. I remember them saying they had trouble finding it. Will let you know. Thanks for the input!
Page of 8
