RV.Net Open Roads Forum: Travel Trailers: Any new developments in hitches?
 > Any new developments in hitches?
Skelshy
Pacific Northwest
Posted: 06/22/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I've had a Surveyor from 2012 to 2018. Lots of good memories. A lot of work. I particularly dreaded hitching and unhitching it. Lug the heavy truck side bit. Put the pin in. Aim with a backup camera. Hope the trailer height is right. Adjust the trailer height. Crank down the trailer. Move the truck half in forward because the safety doesn't go all the way down. Put in the safety pin. Crank up the trailer so the WDH bars can be fit. Fit the WDH bars. Put in the WHD bars safeties. Put in the two chains. Put in the breakaway cable. Crank the crank to lower the trailer. Put in the 7 pin. Remove the wheel chocks. Walk around the trailer. Extend the tow mirrors.
Aren't there any hitch systems you can just drive up to?
It may not sounds like a lot. But on a weekend trip, time really counts.
Owens River Road area, north of Mammoth
Posted: 06/22/20 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Not that big a deal to me.
Hannibal
Tampa Bay Area
Posted: 06/22/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
The only reason I use a WDH, is to satisfy the rating of the receiver. Hitching up isn’t too much of a hassle but I don’t like the stress it puts on the trailer. The new Superduty’s receiver is rated for 1300 lbs dead weight. That’ll carry our 1,071 lbs of tongue weight on a simple ball. Most will disagree.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
GrandpaKip
Flat Rock
Posted: 06/22/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Short answer—no.
However, if your tongue weight is about 700 pounds or less, it’s lots easier to use an Andersen Hitch. Still have to back up straight, stop under the ball and attach everything. Takes me about 5 minutes.
Takes longer to load all of the adult beverages required.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Z71K9
Johnstown, PA
Posted: 06/22/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Hensley Arrow
TomG2
Central Illinois
Posted: 06/22/20 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
2500HD. That and an electric tongue jack reduces time and effort to almost nothing. Press the button, drop the coupler on the ball. Latch the coupler.
Skelshy
Pacific Northwest
Posted: 06/23/20 02:52am Link  |  Quote  |  Print  |  Notify Moderator
Z71K9 wrote:
Hensley Arrow
Can you briefly explain why/how that helps?
Dadoffourgirls
China, MI USA
Posted: 06/23/20 04:53am Link  |  Quote  |  Print  |  Notify Moderator
Get a new Silverado with the hitch-view camera. For $45k, you will be properly aligned!
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
ZINGERLITE
Union Lake, MI
Posted: 06/23/20 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I added a $20 camera to my 2006 silverado. I already had the aftermarket touch screen though. back up cameras are a hitching up game changer. I think its better when in the tail gate handle instead of on the license plate though. depth perseption is harder with the camera on the plate. It still makes life alot easier!
subcamper
Buffalo, NY
Posted: 06/23/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Skelshy wrote:
Z71K9 wrote:
Hensley Arrow
I have had the Hensley Arrow for 16 years now.
Great stability, no sway, etc.
However, I would never tell anyone that one of its advantages is faster hitching/unhitching.
Unlike a ball, which can take a pretty severe up/down angle misalignment between the TV and trailer, the Hensley requires adjustment of the hitch to match the misalignment. I usually don't have a problem, but on a bad day you could spend a lot of time adjusting and readjusting, wondering why the stinger won't go in for the last two inches!
Steve
