RV.Net Open Roads Forum: Tech Issues: Off air antenna
 > Off air antenna
kfp673
PA
Posted: 06/30/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Bill.Satellite wrote:
I would suspect you have a short in the coax somewhere. You should try running a new cable directly from the antenna to the power supply. Some of the omni style antennas have the connection under the base making this a difficult option. You could start by simply using a multi-meter to see if the coax is grounded (shorted). There should not be any continuity if you touch the center wire and the outside collar.
Thanks Bill. Where do you suspect the power supply might live? Up in the ceiling somewhere? I cant imagine the wall plate is powered directly from the battery without some sort of power supply in line adjusting amperage but I could be wrong.
When I pulled down the plate I pulled as much slack as it would give (only about 6") and all I saw was a few wires that appeared to be power wires plus I think 3 or 4 coax. The coax were run to a splitter which likely goes throughout the camper.
Thanks again!
Bill.Satellite
Full-timer
Posted: 06/30/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
The wall plate IS the power supply. It's not a booster or anything special, it just allows the 12V power being supplied to the wall plate electronics to be passed into the coax that leads up to the antenna itself. There are some antennas (not good ones!) that have a separate booster but not too many any more.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
 > Off air antenna
