RV.Net Open Roads Forum: Class C Motorhomes: slide vs no slide
 > slide vs no slide
dave17352
Ne
Posted: 06/23/20 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Here is my question.
We are well into our 60's. We are thinking about getting a class c and the kids will take the truck camper and truck. This class C will be used for lake camping with grand kids and also for travel for just the two of us.
Looking for opinions of pros and cons of slides vs no slides on a newer unit. Probably no more than 2 or 3 years old.
Thanks in advance of any input.
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
50 gal aux tank
Crestliner 1850 Fish Ski boat mostly fishing now!
Renogy 200 Watt solar
Dusty R
Charlotte Michigan 48813
Posted: 06/23/20 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I read, many years ago, that the slide is #1/at the top of the list of things to give trouble.
Most likely they have improved a lot, but I'll bet that they are still at the top.
We had avoided having a slide until 2012, when we bought a new mh, and I figured by that time it would be hard to find a new mh without a slide.
We just made sure that when we were on the road we could stop and spend the night in it without putting the slide out.
Our slide is just the dinette, and it does give more room. But the mh is useable without the slide out.
Dusty
tobydad
MA
Posted: 06/23/20 05:57am Link  |  Quote  |  Print  |  Notify Moderator
The pro is obvious-more internal room. The cons are extra weight, a little more maintenance (lubricating slide rails and conditioning seals - which takes very little time), the biggest con is when the slide will not work. When the slide will not work results in frustration getting the slide in or out and cost of repair.
Dick_B
Palos Heights, IL USA
Posted: 06/23/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
It's easy. Visit one or more dealers/shows and, while sitting in one, think about the activities you will do inside and whether or not the extra room would be beneficial while moving around.
Slides must not be necessary because I haven't seen an Airstream with one.
I have an opinion for us BUT it doesn't count for you.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
folivier
Southeast Louisiana
Posted: 06/23/20 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Make certain that you can access all of the essentials with the slide in. I've seen some where the fridge, or cabinets, or even the bathroom was blocked by the slide being in. Most if not all dealers will have the slides out and grumble if you want them to pull the slides in.
wildtoad
Blythewood, SC
Posted: 06/23/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Many slide issues fall into the category of self inflicted wounds. Not following instructions, not performing maintenance, forgetting to unlock the slide locks. Nobody gets on here and touts how well their slides work, rather how theirs got stuck.
If it's just you and spouse you might do well without slides. More folks need more room. If you find a late model W/O slides get in it and imagine being in it for an extended period of time. You’ll figure it out.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
memtb
Wyoming
Posted: 06/23/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
The slides have been and will continue to be an issue on many units....class c’’s, class a’s, and tow behinds. There are some units that have minimal to zero issues with slides, while with others it’s a continuing problem. Slide issues or non-issues are a product of engineering design and the quality of materials that the manufacturer puts into their units. We have had 5th wheels (only one manufacture) dating back to 1990....with zero issues. Our present Class C has a slide, which we rarely use. If we stop for just a “one night stand”.....we don’t use the slide. If we’re gonna remain for multiple days, we use the slide....as it creates much more comfortable living space. If we have grandkids or other folks with us.....the slide is a “huge” plus! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
jdc1
Rescue, Ca
Posted: 06/23/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
I have a 20 year old 5th wheel. The slides have NEVER failed. I can access EVERYTHING just as if there were no slide.
One great slide plus is the interior storage. They grandkids really use the added floor space too. We don't have to crawl over them....we can walk around them.
DrewE
Vermont
Posted: 06/23/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
For a newer class C, it's very nearly a moot point; you will get one one or more slides with the great majority of motorhomes available. There are not too many non-slide floorplans available, and those that are I suspect exist mainly to satisfy the rental market.
Slides are not perfect and do occasionally fail, no doubt, but for the most part they must be pretty reliable or they wouldn't be so nearly ubiquitous. Plenty of other things in RVs can give bother now and again, too; generators and furnaces and air conditioners and roofs and doors also need maintenance and the occasional odd repair to work properly and reliably.
pauldub
North of Seattle
Posted: 06/23/20 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I'm not a fan of slides because I'm paranoid about water leakage and the damage that it causes. That being said, there aren't very many class C units anymore that don't have slides. Lazy Daze is one brand with no slides.
 > slide vs no slide
