RV.Net Open Roads Forum: Fifth-Wheels: Waterproofing the 1/8" thick exposed plywood
 > Waterproofing the 1/8" thick exposed plywood
RobWNY
Jamestown, NY
Posted: 06/23/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
On the inside wall area of the outside kitchen, pass though storage compartment and propane tank areas of my 5th Wheel, there is exposed plywood or paneling type material. The most concerning would be where the propane tanks are mounted because it's open underneath and spray will get in there if traveling when it's raining or there's wet roads. Sooner rather than later it will rot. I'd like to avoid that before it starts. Any ideas what I should do to protect it?
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Huntindog
Phoenix AZ
Posted: 06/23/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Ouch. That is not good.
I think the best way is to have it and rthe surounding area sprayed with bedliner.
Next best would be the DIY bedliner in a can. I have done a wood floor in a cargo trailer with it, and it worked great,,, But since you are working upside down, I think it would be hard to do a good job. Perhaps they make that stuff in a spray can now? Whatever you do, wear PPE! eyes, and breathing protection!
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
STBRetired
I-80 and I-55
Posted: 06/23/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
They still sell "undercoating" in spray cans at auto parts stores. Not a good as bedliner, but it will do in a pinch.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
MFL
Midwest
Posted: 06/23/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I had a few unfinished plywood edges, a bit thicker than that, underneath my propane and pass through areas, that I just primed/painted. It has stayed sealed, no issue for years. I used a brush, so no mess or over spray.
Jerry
jdc1
Rescue, Ca
Posted: 06/23/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Why not use duct sealant? It's thick, sticks to ANYTHING, pliable (stretches), and weatherproof. Brush it on. Water clean-up. I used under my trailer where the tire blew a hole in my heater ducting. It holds up WELL.
CapnCampn
Idaho
Posted: 06/23/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I was going to suggest brush on polyurethane or some sealer like that, but I think MFL's suggestion of painting it would be just as good. It seems to work on house siding, right?
CC
RobWNY
Jamestown, NY
Posted: 06/23/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I decided to take a combined opinion approach. I bought a pint can of Flex Seal Liquid and will be painting it on. Hopefully it will last since it won't be exposed to UV rays and weather unless as I mentioned I'm traveling down the road during rain. It's an inexpensive repair and I can always go over it each year.
BurbMan
Islip, Long Island
Posted: 06/23/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I was going to recommend Flex Seal as well. I had some framing under the slide in our TT that was wrapped with Darco...water got in, couldn't get out, and the wood rotted. When I rebuilt the floor I sprayed the replacement lumber with Flex Seal and it's help up great for 7+ years.
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Under renovations:
SOLD: 2001 K2500 Suburban LT 8.1L/4.10
2008 Terry 34' TT many mods, Hensley Hitch
Huntindog
Phoenix AZ
Posted: 06/23/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Don't stop at just the edge. fill the gap between the wood and what appears to be metal tubing. This is why I thought a spray on product would work better... Gravity is gonna fight you trying to get it into the crevices
RobWNY
Jamestown, NY
Posted: 06/23/20 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to squeeze some caulk behind the piece that isn't flush and clamp it until dry. The two pieces are butted up tight to one another so it's just that one small gap. After it's dry, I'll use the Flex Seal.
