RV.Net Open Roads Forum: Fifth-Wheels: Waterproofing the 1/8" thick exposed plywood
 > Waterproofing the 1/8" thick exposed plywood
RobWNY
Jamestown, NY
Posted: 06/25/20 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Flex Seal turned out great! All exposed wood is now sealed.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
MFL
Midwest
Posted: 06/25/20 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Good to hear, congrats on a job well done.
When mine was new, I worked on it a little, most every day. My neighbors said they thought I bought a NEW one, so I wouldn't have to be fixing things. I replied, it is new, that is why I am working on it! [emoticon] Many don't realize, it's not the same as getting a new car or truck.
Jerry
RobWNY
Jamestown, NY
Posted: 06/26/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Jerry, Ain't that the truth! So far on this "brand New" RV that I haven't used yet, I've had to repair seam tape, corner molding, had the ladder replaced because it was damaged when we bought it, a Schwintek motor quit after putting the slide in/out 5 times and the sealing of the exposed wood. I'm sure I'm not done yet. I just haven't discovered the rest of what's not right yet. LOL
GDS-3950BH
DC
Posted: 06/26/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Crawl Under and take a really good look for exposed bottom edges of the 1/8" Luan that is the substrate behind the filon on the sidewalls, especially in the wheelwells. Our Grand Design Solitude started to delam above the fender skirts. It was the water from the tires hitting a raw edge and wicking up into the plywood like a sponge. Out of warranty so piss off according to GD. $60K POS.
RobWNY
Jamestown, NY
Posted: 06/26/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip on where else to check. I'll do that!
Thermoguy
Graham, WA
Posted: 06/26/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I had to remove my propane tank on my 2006 5th Wheel yesterday. Same idea, open to the outside air underneath. I see the exact same setup that you have in your picture. However, after 14 years, it looks exactly the same, no rot, no degradation to the material. Not sure, but it sounds like you are fixing a problem that doesn't exist.
Huntindog
Phoenix AZ
Posted: 06/26/20 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on how often one tows in nasty weather.
I'd wager most here are fair weather campers.
I am not. Just about always I am going somewhere on a specific date for a reason. And we just take whatever mother nature thows at us in stride... In fact when I am hunting I love nasty weather. It sends most everyone else home.
Hunting is great with less people in the woods.
I will look my new Momentum 398 over closely when it arrives.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FBP, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
300 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
Retired JSO
North Georgia Mountains
Posted: 06/26/20 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
It will be fine. After several years towing the same fifth wheel, I have to clean the area of dust, spiders, and wasp. Never had any sign of water/spray entering that area.
RobWNY
Jamestown, NY
Posted: 06/26/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Whether it needed to be done or not, it was an hour job. Being retired, I have a lot of free time.
Thermoguy
Graham, WA
Posted: 06/26/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
I live in WA....
Just saying, can't get away from wet weather at some point. And, mine is 14 years old...
