RV.Net Open Roads Forum: Truck Campers: Happijac
 > Happijac
K Mac
Lower Hudson Valley N.Y.
Posted: 06/23/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Hi guys, on a recent trip I had my jack wireless remote stop working, and green light stayed on the remote.Luck was on my side only had a couple inches to retractmanually. Manual says, " Receiver needs reset", "insufficient power at receiver to operate jacks,(Red light on receiver panel)". I can't see where there is or would be a light, or a reset. Had to remove battery from remote to shut it off. Next day all was well. Can't get through to Lippert (new owner),leaving messages, waiting. I can't find a model or part # on jack,remote, receiver, or in manual, (3 pieces of loose paper) lol. TC is a 13' Northern Lite 10-2 cdse, does anyone have same and know the HJ's model #.... Also searching for the MALE socket for a drill, 6 sided 1/2", all my searches are to no avail, where did you get your socket. Thanks, K Mac.
Camping near Pearsonville, CA
Posted: 06/23/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Has Lippert responded?
AnEv942
CA
Posted: 06/23/20 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Cant help with remote issue. Hex driver bits common, but likly be 3/8 or 1/2 sq drive so adapter would be needed also common (assuming 1/4 cordless hex drive)
The 1/2" male hex x 1/4" hex isn't that common. Close would be a pipe plug remover but they arent cheap for single bit, about $30.. Proform 67447 Pipe Plug Removal Tool.
umm...This popped up HAPPIJAC Hex Drive Camper Jacks [image] amazon.com/Lippert-182912/dp/B01GP5BSGS/
Our camper projects page
54suds
adk mts.
Posted: 06/23/20 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
welcome to world of "crappy jack " champions of world class & renowned non service
ps check your camper battery power level
* This post was last edited 06/24/20 06:52am by 54suds *   View edit history
2020 Chev 6.6 (GAS) lt regular cab ,drw,4x/torklift tdn's,
1999 Bigfoot 1011
Joe417
AL
Posted: 06/23/20 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
To run the jacks up and down with a drill, all that you need is a bolt with a 1/2" head. Any hardware store.
Joe & Evelyn
K Mac
Posted: 06/24/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, I use a bolt now ,but the threads tend to slip in my drill, Batteries are brand new and I had shore power. Still no response , would still like to know jack model #.
54suds
adk mts.
Posted: 06/24/20 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
next: open each through the camper wall jack wire connection clean all connections to assure good connection
* This post was edited 06/24/20 06:17pm by 54suds *
Z-Peller
Oceanside BC
Posted: 06/24/20 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the camper batteries are new, or the remote batteries?.... my jacks quit working one time and remote did strange things. I tried the cord plugged into the jack control box and still would not work. I replaced the remote control battery and that turned out to be the problem. Everything worked fine after that.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
54suds
adk mts.
Posted: 06/25/20 06:22am Link  |  Quote  |  Print  |  Notify Moderator
camper, they can be drawn down by the jack power demand to the point of calling for a reset
ajriding
st clair
Posted: 06/25/20 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Did you try one leg motor at a time to reduce amperage draw on the batteries?
They use a lot of power, and when batt is low will not work. I always plug in when I can when lifting the jacks, so it does not pull from the battery,well, mine are wired directly to the battery I think, not the panel, but the charger is providing power to the same wires...
 > Happijac
