RV.Net Open Roads Forum: Travel Trailers: reese hitch question
 > reese hitch question
Family-of-five
Cardale Pa
Posted: 06/23/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all I am back from a long absence. Feels good. Anyhow We are camping again.My rig has reese weight distribution with trunnions bearing the marks 22210.I had them from my last camper and I am moving up to something bigger soon. I was thinking rather than buy a whole hitch why not get heavier trunnion bars.Are they interchangeable? I would like to step up to 12,000 lbs gross
Lynnmor
Red Lion
Posted: 06/24/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Many are interchangeable, call eTrailer with your part numbers.
BurbMan
Islip, Long Island
Posted: 06/24/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
I would also ask if you can upgrade the bars the Dual Cam style with Dual Cam hangers, the extra sway control will be a welcome addition if you are going longer/heavier.
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Under renovations:
SOLD: 2001 K2500 Suburban LT 8.1L/4.10
2008 Terry 34' TT many mods, Hensley Hitch
kellem
Shenandoah valley,VA
Posted: 06/24/20 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I have the Reese DC and upgraded the trunnion bars several times, they've all been interchangeable.
CaLBaR
Ontario, Canada
Posted: 06/26/20 05:24am Link  |  Quote  |  Print  |  Notify Moderator
I ended up buying a new head when I went from 800 lb bars to 1500 lb bars. I think it depends on how high you need to go on the new bars. I would give Reese technical support a call. I have done that numerous times and they are extremely knowledgeable and helpful.
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
Family-of-five
Cardale Pa
Posted: 06/29/20 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
I did my homework and found I can use heavier bars,and they are interchangeable. I also ordered the dual cam system as advised. I like the way its set up. Anyone here use the dual cam anti sway?
dodge guy
Bartlett IL
Posted: 06/29/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I had the DC with my last 2 trailer. Swapped from the 800lb bars to the 1200lb bars. No problem. Just watch the hitch head. Mine had the older design head and the trunnions would contact the ball nut on hard turns. It would then force the bar down and bend the lower trunnions socket in the head. I called Reese and after I explained my displeasure they sent me a new updated head and I paid the shipping. You can tell the difference. The new design has a raised area where the ball mounts too.
The DC is the best sway control hitch out there. The only thing better are the HA and Pro Pride. I never had an issue with sway with my Excursion and 35ft TT.
BTW, welcome back!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Family-of-five
Cardale Pa
Posted: 06/30/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Did the 800 lb bars hit the nut or the 1200 lb bars? The trunnions look to be the same (from pictures anyway) I ordered them with assurance from etrailer they will fit. Yes very good to be back again. Thanks for the help
dodge guy
Bartlett IL
Posted: 06/30/20 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure. I only had the 800lb bars for a year along with the smaller trailer.
BarneyS
S.E. Lower Michigan
Posted: 06/30/20 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
This thread, stuck at the top of the Towing forum, should give you a lot of help in setting up your Reese Dual Cam system. It is an old thread but is still relevant and good today. It discusses not only the proper setting up of a WD hitch but some of the problems that people have, and the solutions, of the Dual Cam sway control system.
I towed my trailer and the trailer before it with the Reese Dual-Cam system. I never had a single problem with a sway or control event in all those years. I changed to a Hensley hitch later on because I wanted to see if all the "hype" was true. It was! [emoticon]
I continued to use the Hensley system for many years until I quit towing last year and retired our trailer to a beautiful permanent camping spot.[emoticon]
If you take the time to set up the Dual Cam system correctly you will be rewarded with many years of safe, comfortable towing. It is somewhat fussy about things being exactly right on setup but, if you take time and care, it will reward you greatly for doing so.
Barney
Not towing now.
