zb39
slippery rock
I had a new RV 4 door fridge put in my Zephyr DP. They removed the dinette window to get it out and the new one in and it was very tight.
Tiffin Zephyr(sold)
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
BurbMan
Islip, Long Island
The camper door is like 21" wide. If you remove the door the rough opening is like 23". From the Dometic Website
Dimensions product depth 24 11/16 "
Dimensions product height 43 7/16 "
Dimensions product width 24 7/8 "
I remember our TT had a wider door and also had a huge dinette window so that would have made easy access. The opening big enough on this camper would be if the slide was removed.
This is all working out for the best, since the slide needs to come out anyway so I can repair the rot in the frame underneath it. I just wasn't prepared to take it out last night. This also gives us the opportunity to go from a 3-way to a 2-way absorption fridge, since I couldn't find any advantages at all to running on 12v. We always ran the TT fridge on propane when underway and expect to do the same here. We found a brand new scratch-n-dent RM-2551 for about half of what it retails for.
The fridge is right next to the slide out, so with that wall clean, I can rebuild all of the framing, install the fridge and then re-install the slide.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Paradox123
Pine Junction, CO
BurbMan wrote: since I couldn't find any advantages at all to running on DC.
We run our fridge on DC when traveling. The solar panels keep the batteries fully charged as long as there is daylight.
ajriding
st clair
Been there done that...
Window method
NRALIFR
Truck Camping Out West
AJ, that’s awesome. That’s the kind of “I can do this!” attitude I’ve always admired. You have my utmost respect, mainly ‘cause that’s just the way I would have done it! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Unfortunately, the OP’s camper doesn’t have a single window with dimensions big enough to do that. His camper is very much like mine, especially in the size and design of the dinette slide out. The biggest window in our campers is the one above the dinette table. But, because it’s in a slide out, the window rough opening is only about 20” tall.
It’s always good to keep all options in mind though. Your technique may very well save someone else’s day. ![cool [emoticon]](http://www.rv.net/sharedcontent/cfb/images/cool.gif)
![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
2001 Lance 1121 on a 2016 F450
JIMNLIN
Oklahoma
My ignorance but I left the fridge on while parked beside the tractor barn on too much of a side slope. This was in '84.....older units had to be pretty level to work right. Burnt a hole in a fridge tube so I had too remove the door/frame to get the old out. The new fridge wouldn't go through the door opening....so I took the big dinette window out.
ajriding
st clair
Well, there is still hope. You can get a rebuilt cooling unit (the coil metal thing on the back side), and this will fit out the door. The fridge box is fine and can be used forever as long as it is intact.
The bad news is that replacing a cooling unit is no fun when it is on the driveway, but it is possible to do it inside of the camper if you can turn the fridge the right direction to get access.
Slymer
Ontario, Canada
I watched a video once where they put a moving blanket on the dinette after setting it down. Took the old fridge out, put it on moving blanket & cut it in half and out the door. Then the new fridge they took apart, brought the pieces in to the blanket & put it back together & installed it Long process but it worked without damage. Can't remember where I saw it.
Fishbreath
home
I had a 1995 Lance that I had to replace the refrigerator. That was a battle. I did take the entry door apart and completely disassembled the refrigerator. This included removing the spray foam. It was a mess.
I was able to disassemble the new unit into smaller components to get it inside. After reassembly, I was amazed that it still worked.
The entire process was a major pain and I would not want to do it again.
Good luck with your project.
bigfootford
Fair Oaks, California
What is wrong with these camper mfg's?
No way to remove a fridge?
That is some damning engineering in my opinion, or lack of!
We love our BF as we have a couple of others. One camper, a 80 6pac the fridge would fit through the door as the door was BIGGER than todays RV doors...
Are the RV door companies in control of the construction of these campers and RV's?
Just maddening that they are just following the HERD!
Thank god our Fridge is still functional and it is not too techieee. So we can replace the cooling unit if needed. . 20 years and counting and it cools like a champ!
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
