RV.Net Open Roads Forum: Class C Motorhomes: electrical issue
 > electrical issue
singleshot
Missouri
Posted: 06/24/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
we purchased a coachman leprechaun 2020 and first time using could not use both air conditioners and any other appliance without tripping the 30 amp breaker. Dealer says this is normal.
Anyone had a similar problem ?
Mfan
Otsego,Mi
Posted: 06/24/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Move to a 50amp site?
opnspaces
San Diego Ca
Posted: 06/24/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
If your shore power cord has only three blades and you are tripping a 30 amp breaker it's probably normal. If 4 blades you need to find a 50 amp site to run both AC's at the same time.
If only three blades (30a) you can try staggering the starting up of the ACs by a few minutes to try to get them not running at the same time. But ultimately you'll probably only be able to run one AC at a time.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
gkainz
Arvada, CO, USA
Posted: 06/24/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
yep - on 30 amp plug in ... do the math
https://www.ramsond.com/wattage-chart/
RV A/C Starting Running
Watts Watts (AVG)
13,500 btu 2750 1250
15,000 btu 3500 1500
30 amps at 110VAC will handle about 3300 watts (ballpark estimate)
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
BB_TX
McKinney, Texas
Posted: 06/24/20 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
With 2 air conditioners I assume you have a 50 rig and are connected to a 30 amp service using an adapter. True?
Tripping the 30 amp breaker is very common to those used to 50 amp service. Two A/Cs will certainly trip it. One A/C, the microwave, and the water heater on electric will likely trip it. Any combination of high current appliances will likely trip it. No harm. Just reset the breaker and try to remember not to do that combination again.
time2roll
Posted: 06/24/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can't pay a $12,000 charge with $3,600 bucks.
50 amp is 12,000 watts power, 30 amp is 3,600 watts power.
675w Solar pictures back up
whemme
Spencer, IA
Posted: 06/24/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Actually 50 amp service delivers 6000 watts of power, not 12,000 watts. If your rig is equipped with two A/Cs, your shore line power plug should be only compatible with 50 amp service which will run your two A/Cs.
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
time2roll
Posted: 06/24/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Google says 12,000
Rick Jay
Greater Springfield area, MA
Posted: 06/24/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
whemme,
A properly wired 50Amp service consists of two lines (L1 & L2) of 50Amp service, so the maximum power deliverable is:
50Amps x 2 x 120volts = 12,000 watts.
~Rick
* This post was edited 06/25/20 04:43pm by Rick Jay *
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (22-Angel, Lexi96.org), 1 girl (17), 2 boys (19 & 16).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
bob213
Fresno, CA
deleted
 > electrical issue
