RV.Net Open Roads Forum: Class C Motorhomes: electrical issue
 > electrical issue
cavie
Posted: 06/24/20 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
whemme wrote:
Actually 50 amp service delivers 6000 watts of power, not 12,000 watts. If your rig is equipped with two A/Cs, your shore line power plug should be only compatible with 50 amp service which will run your two A/Cs.
50 amp service is 120/240 volts. 12,000 watts. And that's the way it is!
pianotuna
Regina, SK, Canada
Posted: 06/24/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Most 50 amps are wired to provide 6000 watts per leg. That adds up to 12000 watts.
If it is a 30 amp RV, you might be able to add a load support hybrid inverter charger. If the AC units are 13500 each that may allow running both--and other items, short term. Such as a coffee pot.
It would be important to monitor voltage.
Regards, Don
 > electrical issue
