RV.Net Open Roads Forum: When I'm driving do I run my fridge on propane or electric?
 > When I'm driving do I run my fridge on propane or electric?
rvshrinker
Beautiful Pacific Northwest
Posted: 06/24/20 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
We will have 48 hr of boondocking so need the battery to last that long.
sh4717
Las Vegas
Posted: 06/24/20 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Propane. The only way it will run on 110 (electric) is if you have a REALLY long extension cord or a large inverter hooked up to multiple batteries with solar. I would recommend the propane route.
Scott
2019 Northwood Nash 24M
2018 Ram Ecodiesel
1320Fastback
Vista, Ca
Posted: 06/24/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Propane. Electric is when on Genny or plugged in somewhere.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
bob213
Fresno, CA
Posted: 06/24/20 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Even on propane your refrig requires 12v to operate. Factor that in to your usage for 48 hours. While you are driving your 7 pin does not really charge battery enough to make a big difference unless you were driving for a "long" time.
wildtoad
Blythewood, SC
Posted: 06/25/20 04:50am Link  |  Quote  |  Print  |  Notify Moderator
propane for everything - fridge, water heater, etc. depending on how far you’re driving you may consider turning the fridge off until you get where you’re going. To NOT run the furnace if you only have one battery. Do you have a generator to take with you to charge the battery if needed?
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
midnightsadie
ohio
Posted: 06/25/20 05:02am Link  |  Quote  |  Print  |  Notify Moderator
on pp your frig uses very little 12v , you should be fine. BUT the furnace eats 12v. will kill a battery in a few hours. and the frig really doesn,t use much pp.check water in battery clean post charge before you go. if your equipt is in good shape you,ll have a fun trip. don,t take care of things it,ll bite you in the butt just when you don,t need it.p.s air up those tires .
kellem
Shenandoah valley,VA
Posted: 06/25/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
48 hrs is very doable if you watch your light usage and don't run the furnace.
noteven
Turtle Island
Posted: 06/25/20 06:36am Link  |  Quote  |  Print  |  Notify Moderator
no.
yes.
maybe.
Pre-cool the RV fridge for 2 days before leaving,
Switch to electric 12 volt.
Have assistant rev up tow vehicle engine to 2000-2500rpms
Look at voltage reading in the RV electrical system. If it is not over 13.6volts the fridge will gradually flatten the rv batteries while you travel.
ppine
Northern Nevada
Posted: 06/25/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
propane. You alternator is not enough.
Posted: 06/25/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
^Fridge on DC will deplete RV battery either way unless a dedicated charging circuit is set up and verified.
Run it on LP period. Don’t overthink.
Next question.....
