RV.Net Open Roads Forum: When I'm driving do I run my fridge on propane or electric?
 > When I'm driving do I run my fridge on propane or electric?
campigloo
Baton Rouge, La
Posted: 06/26/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
With all the rigs on the road it seems from some posts that a major fire is inevitable in your rig. So true. I’d be willing to bet that any second you’re going to get in a wreck and die. The best thing to do
Is stay off the road completely.
JIMNLIN
Oklahoma
Posted: 06/26/20 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Over 1.2 million miles on the road for eleven years in a nine state area in and out of lots of fuel (gas) stops and never saw a fire started from a LP fridge.
Now LP hot water tanks are another story. Some years back trailers and motor homes were common at my area dealers with the sidewall burned out around the hot water tanks.
First LP fridge was in a new 9.5' 1970 Fields truck camper. Three truck campers ...a TT ...and three 5th wheel trailers all with the LP fridge on. But I do turn it off if required by law.
BarabooBob
Baraboo, WI
Posted: 06/26/20 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I run my fridge on lp while traveling with the exception of when going through the tunnels on the east coast under the big bays. They have signs all over the place that propane must be turned off. I have seen tunnel/bridge authorities pull RV;s over to check them.
I installed a 6 gauge wire from the power distribution center under the hood to the rear of my truck and connect it to the battery on the trailer with an Anderson Powerpole connector. A circuit breaker is at both ends of this to protect against shorts. When I statt my truck, my volt meter in the TT jumps to 14.4 volts. I have checked to see what amps I am getting. I also connect my solar panel/controller to this same plug when we get set up.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
old guy
Oregon (pronounced Or e gun)
Posted: 06/28/20 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
for all of you who have traveled for years and never had a problem I say two words,"NOT YET". One fire we had that involved a motor home and a UPS truck and the station and a 5000 gallon propane tank, he said I turn off my propane so I thought I was safe, turn out after questioning him and seeing the location of the fridge in relation to the gas filler, the propane was off but the fridge was still on. so it was trying to light and one spark lite the gas fumes up and the rest is history. Oh yes, the 5000 gallon propane tank was a propane filling station and our second truck in hit a hydrant and used the mounted steamer nozzle to keep the tank cool. other wise we would probably be replacing half the town not just a gas station. being that close to a large propane tank is just plain scary as all get out and I'm glad I'm not fighting fire any more
deltabravo
Spokane, WA
Posted: 06/30/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
Switch to electric 12 volt.
OP didn't say if his fridge is 2-way (propane / 120 VAC) or 3- way (propane / 120 VAC / 12 vdc)
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Sjm9911
New Jersey
Posted: 07/01/20 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Ok , im late to this. But, I run mine on propane and dont shut it off when refueling. Not by choice, but I forget to shut it off. Now some real life stats, approximately 4500 servicestation fires a year as of last avaliable stats , out of that an avrage of 30 were because of RV , camper fires. That doesn't mean they were propane related, just that they started a fire on the service station property. These stats are the NFPA. So , national fire protection agency. My fridge sits way behind the TV when filling and i will take the rear spot when refueling so no chance for acedential ignition. If you have a 3 way fridge, use the 12 volt option. If not , use the propane. 12 volt isnt great, but it will work. Have fun!
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
CavemanCharlie
Storden,MN
Posted: 07/02/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
You can get hit by lighting too. No use worrying about it.
Actually, I don't know for certain but, you are probably more likely to get hit by lightning then you are to have a RV fridge propane fire.
aftermath
Washington State
Posted: 07/02/20 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
And here we go again. To the OP, if you are boondocking the electrical draw from your propane fridge is minimal. Like others posted, using the furnace will be a big draw. Forget AC, you can't access it unless you have a capable generator and then the the fridge qustion becomes moot.
When discussing traveling with the propane on, avoid any discussion that talks about what terrible thing happen at gas stations. That has nothing to do with traveling down the road. Read all the information but ask about facts, not individual stories. I think if you look for actual cases when a trailer erupts while doing down the road with the propane on, you might be surprised with the extremely small (if any) number.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Turtle n Peeps
California
Posted: 07/03/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
People; this isn't the 1960's anymore. No more mini-skits. Sonny is dead and Char is old.
ALL vehicles have VRS on them. They work so good that some VRS on gas pumps are going the way of the dinosaurs.
I used to love the smell of premium gas being pumped at the gas station in the 1960's. Starting in the 1970's the gas smell started to disappear. Why? VRS! In both the pump and vehicles.
VRS are the reason you don't smell gasoline fumes in the station while pumping gas. There is no fumes to catch on fire anymore.
A little reading about VRS's.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
CavemanCharlie
Storden,MN
Posted: 07/03/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
You link it to VRS on gas pumps. No gas pump in MN has anything like that on them.
You did say that vehicles have them. That could be, I don't know. I do know that I had a Chevy pickup and could not get that gas to go into the tank faster then a trickle. My mechanic said that it was because all the modern cars force the gas fumes from the tank going through a filter and my filter was under the truck and had become plugged up. To fix it he had to run a hose under the hood and move the filter to that location . Common Chevy problem. The filter under the truck is in the dirt and gravel roads plug it up so it has to be moved to work. This was on a 2008 truck they may have fixed that problem by now.
