RV.Net Open Roads Forum: Anyone pulling over 12K with new Ford 7.3 Gasser?
 > Anyone pulling over 12K with new Ford 7.3 Gasser?
ReneeG
Meridian, Idaho
Posted: 06/26/20 08:25am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Njmurvin wrote:
In the TFL towing tests, the 7.3 got 2.2mpg going up the Ike. The diesels didn't do much better (all were towing 16K lbs). But they used the computer calculated mileage so take those numbers with a grain of salt. The big advantage to the diesels was in the downhill run. Far less touches of the brakes in the diesel trucks.
Interesting. Diesel are not know for good engine braking !
Did I read this wrong, "Diesel are not know for good engine braking!" We had a 6.8L gas and it was not good for mountain driving. A "seat of your pants" type of thing. Fast forward to our current TV - a delight up and down steep mountains - in Tow Haul mode, a touch of the brakes, slows it down, another touch of the brakes, and slows it down even more.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Njmurvin
Simi Valley
Posted: 06/26/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah. I have a PacBrake on my 2004.5 Ram (there was no OEM option for an exhaust brake). With trailer in tow, I just descended a 7 degree grade at 60mph without touching the brakes once. I won't tow again with a diesel without an exhaust brake.
I don't even know if you can buy a new diesel from the big 3 that doesn't have an EB.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
johndeerefarmer
Posted: 08/05/20 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Talk to 5star tuning he has two 7.3's and tows regularly. He also posts on the FTE ford truck forum.
Personally only diesel for me. I hate the high rpms and downshifts that gasser do.
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflections 220rk & 29rs
C Schomer
Pueblo West, Co.
Posted: 08/05/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
OP... You have a darn good truck. All you need is a few mods. My 03 HO 6spd 4.10 s, with towing mods, handled my 15k fiver very easily and 20k was still very doable. It was a LOT better workhorse then my 12. You'll be taking a big step backwards if you get rid of it. Craig
2012 Dodge dually diesel. CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
JRscooby
Indepmo
Posted: 08/06/20 04:29am Link  |  Quote  |  Print  |  Notify Moderator
I would still like to see a side by side comparison of engine braking, same displacement gas/diesel exhaust brake. I know the diesel without the add-on has almost nothing, so it would be the difference restricting the air in compare to restricting air out.
Lantley
Ellicott City, Maryland
Posted: 08/06/20 05:17am Link  |  Quote  |  Print  |  Notify Moderator
larry barnhart wrote:
We had a 2001 8.1 gas engine and 3500 2wd dually. We have a 2005 3500 2wd duramax and have driven on I-84 many time with both trucks. Going down the cabbage hill for 6 miles in Oregon there was no difference in being under control towing the same fifth. chevman
Does your 2005 Duramax have an aftermarket exhaust brake.
Exhaust brakes are now standard equipment and make a big difference
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
Njmurvin
Simi Valley
Posted: 08/10/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I said the same thing to my wife. After breaking down twice on the freeway (once with 12k in tow), she insisted it's time to get a new truck. Who am I to argue with THAT?
I ended up staying with a diesel. I qualify for the GM employee discount so I got a good deal on a 2020 Silverado 3500 Duramax. The difference is astounding. I compare it to when I moved from gas to my first diesel truck. It's quieter, pulls harder, more controlled on downhills and gets at least as good of mileage. I credit a lot of that to the 10 speed trans which always seems to find the right gear.
Lexx
California
Posted: 09/10/20 02:01am Link  |  Quote  |  Print  |  Notify Moderator
The new diesels make towing so much easier. Effortless amounts of massive torque means you're never revving the engine unlike a gasser.
And the exhaust brake is a godsend when coming down an 8% grade for several miles. With the adaptive cruise control engaged, I never even have to touch the brakes at all. It makes for a serene towing experence.
2017 Ruby Red Platinum F450 - my kids call her "Big Red"
2018 Grand Design Reflection 28bh
Dtank
Posted: 09/16/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Gas = downshift. You will still need to use brakes on and off to maintain speed.
Diesel = You need to take a test drive! "Back when" with my 1985 Ferd diesel - there was no compression braking. A downshift to a lower gear was necessary.
Exhaust brakes were optional on RAM trucks with manual transmissions in 2005. With automatic trans in 2006. After that, like the poster says - standard equipment.
No need to use the (hydraulic) brakes on a downhill - except for a complete stop.
BTW - HDTs (Heavy Duty Trucks) have had "Jake Brakes" for years - including 3 stage. Yes - a Jake Brake (HDT) and an EB (LDT) -some mfg by "Jacobs"- are two different animals that achieve the same excellent results.
JRscooby
Indepmo
Posted: 09/16/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Sometime in the mid '80s I swore I would never by another gas engine if I expected to gross over 50,000 lbs. About the same time I decided I would never put a bed on a truck that did not have a jake. I do have a understanding of the abilities of the engines.
My 1693 Cat had more go and more whoa than any 855 CID Cummins I was around. My 3406E had more go and whoa than the N14s I worked with. All of them, the driver had to downshift to keep jake slowing. But none of the diesels ever would slow a load if the jake was off.
Gas engine, normal operation, you control the amount of air going in. Load pushing engine, close throttle, restrict air into engine, the load slows.
Diesel, a add-on restricts the exhaust, air flowing out of engine. Load push engine turn on exhaust brake, the load slows.
What I have never seen is to like sized engines, same load, same gears, same grade, compare the whoa.
