RV.Net Open Roads Forum: Grey water pump into portable waste tank
 > Grey water pump into portable waste tank
mbopp
Henrietta, NY, USA
Posted: 06/29/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
My "tote" is a 30 gallon barrel ($10) strapped in my truck bed. I fill it with a Flojet macerator pump and it has a 1-1/2" gate valve and hose to empty it. I started with a Harbor Freight 12V marine pump but the macerator is faster and I can empty the black tank with it.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
Matt_Colie
Southeast Michigan
Posted: 06/29/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
cougar28 wrote:
Get one of these. With my Dewalt 18v drill it will pump 5 1/2 gpm and will work pumping gray water. I use one to transfer fresh water from a tank in my truck bed into my RV holding tank. Works really well and cheap.Drill pump
Can you tell me why you want to put water INTO your holding tank?
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
cougar28
Lowell,AR USA
Posted: 06/29/20 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Matt
Guess I should have said fresh water tank. The talk was about holding tanks and had that stuck in the old noggin.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
dbischops
Posted: 08/01/20 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
Just wanted to post a follow up message.
I ended up buying a ryobi cordless pump, since I already had batteries.
The only challenge I ran into is that both the pump and the valve cap had a male connection, which I could not connect the supplied water hose to. I only had a walmart close and I found a quick disconnect set that worked, but it had a strainer in it.
The pump worked great, but when dumping the galley, the strainer would get clogged up with food particles. But that was easy to clean out.
I appreciate all the feedback.
beemerphile1
Ohio
Posted: 08/02/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
dbischops wrote:
...both the pump and the valve cap had a male connection, which I could not connect the supplied water hose to. I only had a walmart close and I found a quick disconnect set that worked....
For future reference, a washing machine hose has two female ends. I always keep one in my gear.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Bobbo
Wherever I park
Posted: 08/03/20 06:38am Link  |  Quote  |  Print  |  Notify Moderator
You can also get a 6' hose reel leader hose with two female ends.
Bobbo and Lin
