RV.Net Open Roads Forum: Ford v10 stalling in the first five minutes
 > Ford v10 stalling in the first five minutes
ocean bound
plains Pa.
Posted: 06/25/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Georgetown Ford V 10 Lately when I start it Then head out It will stall in the first five or 10 minutes when I come to a stop sign Or light And restarts with no problem and does not do it after that Any idea what it could be And it runs perfect after that
Allen&carrie 2006 georgetown XL359 37ft
crawford
Dandridge Tenn.
Posted: 06/25/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
why not go to any parts houses most do free scans see what it says no guessing
Change from a c class to a A class Georgetown 07 triple slide
theoldwizard1
SE MI
Posted: 06/25/20 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Pre OBD-II
wanderingaimlessly
SOBOVA
Posted: 06/25/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Pre OBD-II
Is that chassis specific?
I thought OBD was mandatory since the mid to late 90's. I know I have used mine on Auto's and light trucks back to that era.
Yankee Clipper
Cairo, GA
Posted: 06/25/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
It may be time to flash the PROM. 5-Star Tuning may have the solution.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
camperdave
northern, California
Posted: 06/25/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
My van does that sometimes (1998 V10). Seems to be only after sitting for a while, I kind of think it may have to do with the evaporative emissions stuff but that's just a guess. I'm ODB2, but it never throws a code. I also have a 5 star tuner installed (love it), so not sure that's a solution either lol.
2004 Fleetwood Tioga 29v
MountainAir05
New Mexico
Posted: 06/25/20 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Our 99 does it only in the cooler weather. I just let it warm up and slowly get up to speed and its fine. Never figure out why it does it and never a code.
Home Skillet
Pearland Texas
Posted: 06/25/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm willing to bet it's the throttle body.
Mine was doing the same thing.
I was a Ford Technician for 25 years. I've replaced a ton of throttle bodies.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
ocean bound
plains Pa.
Posted: 06/25/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody for the information I have a scan gauge up to it and it never throws any kind of code Throttlebody does make sense or mass airflow sensor maybe
patperry2766
Saginaw Texas
Posted: 06/25/20 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Try cleaning the mass air flow sensor and throttle body, then reset the throttle body calibration. Most likely it is the throttle body, but at least try a cheap $10 fix first to see if it solves the problem.
ALso probably wouldn't hurt to run some Seafoam in the gas every few thousand miles just to keep the system clean.
calibration
throttle body cleaning
MAF cleaning
* This post was edited 06/25/20 10:28pm by patperry2766 *
Courage is the feeling you have right before you fully understand the situation
