RV.Net Open Roads Forum: Travel Trailers: dry docking and charging
 > dry docking and charging
guscampag
Ohio
Posted: 06/25/20 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a small travel trailer and have set it up with (2) 6-volt batteries for drydocking. When I arrive to a destination and the batteries are fully charged, we do not use much electricity and the batteries will remain charged for about 5 days. I will then charge with my 3000 Watt Champion Inverter Generator. The problem is that even after running several hours and the gauge showing a full charge, the batteries will only last about a half day and need recharging. I don't understand what is happening here. Any insights would be greatly appreciated!
thanks.
2oldman
New Mexico
Posted: 06/25/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Please clarify this statement..are you powering a converter, or does the generator have a 12v outlet?
bigorange
Tucson, AZ
Posted: 06/25/20 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Are you running the batteries all the way down? It will take longer to get them back to full charge If you fully discharge them. I’d run the generator a little more frequently than 5 days to top them off more effectively.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
wanderingaimlessly
SOBOVA
Posted: 06/25/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you are charging using the built in converter, it will charge about the first 70% in just a couple hours, to finish takes much longer. Thats one more reason so many folks love even a small amount of solar. You can get most of the way in a couple hours off the genny, and then let the solar take all day topping off.
time2roll
Posted: 06/25/20 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Check your charging voltage. You need 14.2+ volts on the battery or you are looking at 12 to 24 hours to be fully charged. Many only go 13.6 even when labeled as multistage converters. WFCO is especially notorious at this.
Consider a replacement like this:
http://www.bestconverter.com/PD-9260C-148-60-Amp-RV-ConverterCharger
675w Solar pictures back up
KD4UPL
Swoope, VA
Posted: 06/25/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
What gauge are you looking at? The little Full - 2/3 - 1/3 red light gauge? If so, that thing is useless. It's looking only at voltage. The voltage is high anytime the converter/charger is operating. An actual battery gauge that uses a shunt like those made by Tri-metric, Magnum, and others will give you 0 - 100% reading of what's in the batteries.
Some RV converter/chargers are notoriously bad. Most people don't really do much camping off the grid thus they don't need a good charger thus the RV builders don't install a good one to save cost.
Don't use the 12v output from your generator. It is also useless. Plug the RV into the generator just like plugging into an outlet and let the build in converter/charger do it's job no matter how poor it may be.
philh
Belleville MI
Posted: 06/25/20 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
new convertor/charger is needed
Vintage465
Prunedale CA.
Posted: 06/25/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
And a real gauge, make sure you don't take your battery bank down lower than 60%.
12.6/7=100%
12.5=90%
12.4=80%
12.3=70%
12.2=60%
If you went 5 day's that'd prolly be lower than 60%. There is a lot of info on this forum in different places for charging and good use practices. The options for charging types and battery banks are as wide as the world. Choosing what is best for you takes time and trials.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
West & above Bishop, California
Posted: 06/25/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Daily full recharging is best for deep cycle batteries, not what you are doing. An adequate solar system would eliminate the generator use almost every day.
ssthrd
Vancouver Island
Posted: 06/25/20 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
This year we have been boon docking quite a bit, and so we picked up a couple of 130 watt solar panels to look after our two Trojan T105 6v golf cart batteries. They work great for me. We have to chase the sun a few times a day, but no big deal.
We have been usually down to 70% or so when I check the battery controllers in the morning, and it only takes a few hours to get them back to 100% again on a nice clear day. Mine even charge on cloudy days, but of course not nearly as well as on a sunny day.
I have a 2000 watt gen/inverter for those nasty days. We were set up for 14 days, and used the generator only once initially to get things going. We also have a couple of small 100 watt USB inverters to charge our electronics in the trailer.
The beauty of these solar panels is that they automatically stop when the batteries are 100% at which point they go into a maintenance mode similar to a battery tender. Just have to check the water level in the batteries now and then to make sure the plates are covered.
I have no idea if the performance that I have seen is typical, but I sure am happy with the results for our purposes.
2013 Wilderness 2750RL
2018 GMC Denali 3500HD with Duramax
DeeBee, JayBee, and Jed the Black Lab
