RV.Net Open Roads Forum: Travel Trailers: dry docking and charging
 > dry docking and charging
philh
Belleville MI
Posted: 06/26/20 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Vintage465 wrote:
And a real gauge, make sure you don't take your battery bank down lower than 60%.
Is that still true for GC2? I understood them to be able to go a lot lower.
ajriding
st clair
Posted: 06/26/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
While the gen is putting a 12DC charge on the battery whatever DC charge gauge you are reading will read full, this is because the generator is putting full voltage on the battery and the gauge sees this as a full battery, remove the generator and your battery will go back to only a partially charged voltage and this will show on the gauge, but sometime there is a "surface charge" that will sit on the battery, some kind of electrical mystery, but that surface charge will go away after just a very short time of using lights, within minutes.
The generator probably only provdes very minimal DC power (amps), so will take a very very long time/ multiple tanks of gas to recharge two low batteries.
Better to plug a good battery charger into the AC plug of the generator and charge the batteries off the charger.
Solar is really the way to go. You batteries will last a year or two longer, maybe 3 or 4 years longer since you are hard on them running them down like you described. 100 watts will suffice and 200 watts is plenty. They key here is the charge controller (takes current from the solar panels and controls what goes to the battery). MPPT is what you want not the $20 ebay one, but at least $50 range will do. 20-30 amp model is enough for what you describe. You batteries will be topped off nearly all the time.
ppine
Northern Nevada
Posted: 06/26/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
If you have conventional wet cell batteries, you never want to run them down. Use your charging system every day and keep them up.
West & above Bishop, California
Posted: 06/26/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
"I have no idea if the performance that I have seen is typical,.."
ssthrd, sounds to me that you have a very adequate solar system doing what it is supposed to do.
Posted: 06/26/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
"Is that still true for GC2? I understood them to be able to go a lot lower."
Your choice how low you go, philh. The lower you go the fewer cycles you'll get. See the Trojan cycle chart at
https://www.trojanbattery.com/products/deep-cycle-flooded/signature-line-flooded-2/
Cycle to a 60% discharge you'll get 1,000 cycles.
Cycle to a 40% discharge you'll get 1,500 cycles.
2oldman
New Mexico
Posted: 06/27/20 09:22am Link  |  Quote  |  Print  |  Notify Moderator
OP is gone.
guscampag
Ohio
Posted: 06/27/20 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like my best bet is to go with a couple of solar panels. I was thinking about doing that but didn't think I would really need them since I had the generator. Renogy 200 W suitcase panel is on my list.
Im only have the 1/3 - 2/3 "battery gauge" and I think I have a cheapo convertor. Hopefully I won't need to change these right away. The suitcase panel comes with a Voyager controller. I have (2) of the 6 volt Trojan batteries which are very new.
thanks for all the suggestions.
* This post was edited 06/27/20 01:31pm by guscampag *
Boon Docker
Posted: 06/27/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
OP is gone.
I didn't see him leave. [emoticon]
2oldman
New Mexico
guscampag wrote:
Sounds like my best bet is to go with a couple of solar panels..
You haven't answered any questions.
ajriding
st clair
Posted: 06/29/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Yes, solar.
The generator is really just for running the AC when boondocking, otherwise leave it home (unless there is no sun where you are). The solar will do the bulk of the work.
