RV.Net Open Roads Forum: Class A Motorhomes: Turn signal/ flasher help
 > Turn signal/ flasher help
iamalienru
Yucaipa California
Posted: 06/27/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I own a 1998 American Eagle. The flaher and engaging the right turn signal blows the 10 amp fuse for the flasher. I have changed the bulbs cleaned up the sockets checked the relays for resistance all good. Left turn works will not blow the fuse soon as you turn to the right it blows. Waiting for a 10 amp breaker to come to see if there is a spark somewhere but probably it wont show. Pulling the column control seems to be a big job. Any ideas would be much appreciated
Tom
enblethen
Moses Lake, WA
Posted: 06/27/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have red turn signals or amber? separate from brake lights?
If you have separate turn signal and brake lights, do you have a 3 to 2 combiner for trailer receptacle? Would/could be at rear of rig.
Did you check all lights that function with turn signals? side markers? front? mirrors?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
iamalienru
Yucaipa California
Posted: 06/27/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have 3 seprate lights red amber and somewhat clear or white brake turn and bake up put new trailer receptacle at the rear running lights are in conjunction with headlights didnt know mirrors would be part of turn signals all light seem to be functional except for middle amber right side turn signal its a maze of wiring getting frustrated but will check mirriors and any other ideas thanks
enblethen
Moses Lake, WA
Posted: 06/27/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Is the trailer connector wired for combined brake and turn signal? If so then there is a 3 to 2 combiner which needs to be checked out. Best way is to disconnect problem wire to it.
iamalienru
Yucaipa California
Posted: 06/27/20 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
7 blade connection brake sperate from turn signal i had it all disconnected still had the problem the mirros have amber lights on the bottom of them dont know if theflash with the signal lights but im going to check in the morning or if they are running lights if they are working interesting
enblethen
Moses Lake, WA
Posted: 06/27/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
some rigs have mid-ship side lights
enblethen
Moses Lake, WA
Posted: 06/27/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Forgot to ask if the emergency flashers work
iamalienru
Yucaipa California
Posted: 06/27/20 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Pulling the flasher blows the fuse
enblethen
Moses Lake, WA
Posted: 06/27/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
physically pulling turn signal flasher blows the fuse? That could indicate bad flasher.
iamalienru
Yucaipa California
Posted: 06/28/20 07:00am Link  |  Quote  |  Print  |  Notify Moderator
I put a new flasher in
