RV.Net Open Roads Forum: Class A Motorhomes: Turn signal/ flasher help
 > Turn signal/ flasher help
iamalienru
Yucaipa California
Posted: 06/28/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Let me clarify i replaced the relay not the switch i was hoping not to get in the column thats the last resort
Tom
enblethen
Moses Lake, WA
Posted: 06/28/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Most rigs the emergency (hazard) wiring does not go through the steering column wiring for turn signals. If emergency flashers work, then problem could be near or in column. If they don't work then it is more apt to be in wiring beyond column.
Where is your emergency flasher switch?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
iamalienru
Yucaipa California
Posted: 06/28/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
The switch is on the column under tturn signal arm pulling the flasher switch or signaling right blows the 10 amp fuse for the flasher
enblethen
Moses Lake, WA
Posted: 06/28/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
That is similar to my GM chassis.
That tells me we(you) are somewhat back to checking all lights for a shorted socket or wiring issue.
Does your rig have a wiring compartment under the driver's seat area on the outside of the rig? If so you maybe able to locate wires to isolate problem.
iamalienru
Yucaipa California
Posted: 06/28/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I found it thanks to enbelthen To all American coach owenrs your side mirrors are connected to your flasher and turn signals if the mirror shorts your turn signal and flasher fuse will be effected
Thank you
enblethen
Moses Lake, WA
Posted: 06/28/20 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update! Glad I was of some help.
Easy fix?
Executive
Posted: 06/28/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Fixing things are harder when you're an alien. [emoticon]. Glad to hear it was an easy fix and not too costly....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
iamalienru
Yucaipa California
Posted: 06/28/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Not easy in respect to the frustration and time but not costly born and raised in southern California 66 years ago that probably accounts for my not figuring out things that quick thanks again
