RV.Net Open Roads Forum: Replacing toilet in 2005 E450 Fleetwood 26Q
 > Replacing toilet in 2005 E450 Fleetwood 26Q
rondeb
Pacific Northwest
Posted: 06/28/20 01:56am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the toilet in a 2005 E450 Fleetwood 26Q and if so which model did you buy. We have replaced toilets before and I thought I would ask here before I start researching what will fit. The toilet that is in there is so tiny, we would like to have more of a stick built home feel. Thanks for any responses.
garyemunson
Reno, Nevada
Posted: 06/28/20 05:24am Link  |  Quote  |  Print  |  Notify Moderator
A porcelain toilet is the ONLY way to go!
valhalla360
No paticular place.
Posted: 06/28/20 06:14am Link  |  Quote  |  Print  |  Notify Moderator
Look for one of the tall models and yes, porcelain is nice. Check the model, the adapter plates and seal at the floor are not all identical.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
rhagfo
Portland, OR
Posted: 06/28/20 06:16am Link  |  Quote  |  Print  |  Notify Moderator
X2
IAMICHABOD
Sunny So Cal 90713
Posted: 06/28/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
On my 2006 Fleetwood Tioga 26Q I replaced the old one with the Aqua-Magic Bravura
I did a lot of research and measuring and found that the low profile one would fit best because of the step up that the toilet sits on.
The things I like is the foot flush, larger seat,the lid and seat comes off easily for cleaning. Also the water module is easy to access for hook up and if needed to be replaced it is simple,most others to replace a leaking water module you have to remove the whole toilet.
Full disclosure I had to replace my leaking water module after 10 years of service,it was an easy fix unlike the others that I looked at.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
rondeb
Pacific Northwest
Posted: 06/28/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
A tall model will not fit as the toilet sits up on a step. We have replaced all our stick built toilets with talls and love them
bobndot
Posted: 06/29/20 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Some rvs have H/C plumbing lines that run on top of the rv floor behind the toilet . If that's the case,they are housed inside a covering that could interfere with the water valve behind the rear of the toilet. Make sure you have the clearance.
rondeb
Pacific Northwest
Posted: 07/02/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
In a previous RV we had we had to drill a hole and re-route the water lines for clearance. That is why I asked for anyone who has replaced their toilet in our current model. Saves time and energy doing the research LOL
