RV.Net Open Roads Forum: Tech Issues: Is it OK to mix battery types??
 > Is it OK to mix battery types??
sprintstream
At Home
Posted: 06/28/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new trailer along with its accompanying new 12v deep cycle battery. I also have a nearly new large 12v diesel starting battery just sitting in the garage. I would like to hook them up together to improve my available AmpHrs. Is there any problem to doing that I don't see? It irks me to have the diesel battery sitting there doing nothing. (yes, I know to hook them in parallel)
Was living the dream in the Ozarks
Now just living
near Jawbone Canyon, CA
Posted: 06/28/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Starting batteries don’t do well with long, low amp hour discharges. Not built for that type of service.
time2roll
Posted: 06/28/20 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it is OK. May as well put them to use.
675w Solar pictures back up
midnightsadie
ohio
Posted: 06/28/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I don,t agree one battery could be weak ,it will draw the other down. you,ll get some input just wait, I,ve all ways been told mixing battery,s a no,no. sell that diesel battery and get two the same.
pianotuna
Regina, SK, Canada
Posted: 06/28/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to wire the batteries in a balanced manner.
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Regards, Don
Dusty R
Charlotte Michigan 48813
Posted: 06/28/20 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
After we had had our mh for a couple of years, that only had one battery, I wanted to add a second battery. So I added a double throw switch, which allowed me to use only battery at a time and switched them every day. But paralleled them while driving to charge them. That kept them rather equally charged, and worked fine.
2oldman
The Q
Posted: 06/28/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Other than what that diesel battery must weigh, it would work.
valhalla360
No paticular place.
Posted: 06/28/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Generally a bad idea. It's unlikely that they will hold a consistent charge which means the weak battery will constantly be drawing the better battery down.
If you want to take the trouble to wire them up as separate banks that are kept isolated except for charging, that's OK.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
dougrainer
Carrolton, Texas
Posted: 06/28/20 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
You can add mixed and mixed age batteries. But, it is not a good idea. A older battery will cause problems with the newer battery and can cause the newer battery to fail prematurely. Interstate Battery, one of the largest makers of Batteries in the USA, They have a policy, If just ONE of their batteries fail during warranty, they replace ALL the batteries in that battery bank. Now to your situation. The RV battery SHOULD be a deep cycle battery. A Chassis battery is NOT. So you will be mixing a Deep Battery with a standard Battery, which is not good. Doug
sprintstream
At Home
Posted: 06/28/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I really appreciated the "balanced battery" post. Made a lot of sense. I'm thinking if I can figure out a good battery tray (yes, the diesel battery is big) that just might take care of the issue of old/new mix. Thanks for the comments.
