RV.Net Open Roads Forum: Howdy. New Owner With Questions Not Found in the Manuals.
 > Howdy. New Owner With Questions Not Found in the Manuals.
longbedbob
WV
Posted: 06/28/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
My wife and I recently purchased a dealer holdover 2019 Cruiser Aire.
It is currently parked at our weekend cabin while we demolish the old structure and rebuild on site. I ran a dedicated 50 amp RV outlet so it is plugged into shore power.
We've spent a few weekends in and developed an idea for what camper living is about and some of the alterations we'd like to make.
I've also developed a list of questions that I can't seem to find answers to on my own.
1. I have the Renogy 200 watt solar kit and two Interstate 100 AH deep cycle batteries. I understand that they are flooded, lead acid batteries that will require maintenance and that I am limited to 50% depth of discharge. However, my question centers around the charging aspect. Since we are away five days each week, I am concerned that the onboard three stage charge controller will "fight" to maintain a float voltage. Based on the Renogy controller, the battery is maintaing 13.7V. But is this due to solar or the "smart" onboard controller. I'm concerned that one source might be trickle charging while the other, operating at a different set point, might still be boosting. I suppose that I could always open the solar panel breaker, but the power is unreliable there.
2. I had been keeping an eye on the gray and black water tanks. My unit has two gray water tanks. The bath/shower water level was 2/3 and the kitchen tank was 1/3. However, last night the sink was backed up. On a hunch, I drained the front gray water tank and the problem was solved. This leads me to ask two follow up questions: a.) Why did my shower not overflow first? Is there a check valve in place to prevent that? b.) How do I calibrate the water tank sensors to better reflect the water levels? This is a no name, all in control panel with no obvious rheostats to adjust. Could the be on the hidden, back side of the panel?
3. The unit came with a wine chiller. Pardon the ignorance here, as I've never before owned one, but are they useful as a refrigerator? We thought it might work as a second refrigerator but it's been disappointing. No matter the temperature setting it never seems to get cold, yet runs almost all of the time. It might be suitable for chilling wine, but I can't imagine storing food inside for long. I want to ditch it for either a proper dorm style refrigerator or maybe use the space for storage.
4. Back to batteries....if I add two additional flooded batteries for a total of 400AH (200 usable) and a 3000 watt true sine wave inverter, would that be enough surge capacity to handle a microwave without overworking the batteries? I understand that Li Ion would be ideal. Given that this is essentially a trailer that won't move much, I am not concerned about the weight gain but do fuss about the nearly $2000 price tag for the equivalent storage capacity.
I'm sure that there are other questions that will come with time, but knowing how to address these issues will allow to move on to discover others.
Thanks.
pianotuna
Regina, SK, Canada
Posted: 06/28/20 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
1. My solar charge controller "plays well" with the OEM converter in my RV.
2. The idiot lights for water levels are rather rarely accurate, except for the fresh water tank.
3. Sorry don't know
4. I won't likely ever get LI. My next set of jars will be based on SiO2 which can be charged and used at -40. Currently SiO2 are about 1/3 the price of LI. The 3000 watt inverter will easily power the microwave. The inverter would be happy with 400 amp-hours, so long as the cables to it are short and FAT.
Regards, Don
StirCrazy
Kamloops, BC, Canada
Posted: 06/28/20 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have 470 ah of batteries ( 4, 6V 235AH ) with a 2000 watt inverter. We can use the microwave and coffee pot as long as it isnt to crazy. I also have 480 watts of solar and when the 5th wheel isnt being used it is pluged in and I have had no issues with the solar power and chager both feeding for the last 4 years.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Big Katuna
Deland, FL
Posted: 06/28/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
We had a wine cooler. We used it to store bottled water. We replaced it with a 2’ cubic foot fridge/freezer which can be adjusted to be a fridge OR a freezer.
Ignore the Guages.
My Kharma ran over my Dogma.
CA Traveler
The Western States
Posted: 06/28/20 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I've had 3 compatible battery charge sources: solar, alternator and gen/charger while driving. No problems. And shore plus solar is SOP.
The typical idiot tank level sensors only serve one purpose: The salesman tells you what a great monitor system you have. My fresh water one is reasonable.
The ideal wine tempeature is 57F and it's not a refer.
MW will be fine. But be aware that they can draw 150A DC so the typical few minutes of use is best. But be aware that at those draws proper wiring is critical - ie short and big.
2014 Grand Cherokee Overland
Bob
Super_Dave
Harrisville, UT
Posted: 06/29/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
1) Why not leave it plugged into shore power 100% of the time?
2) Are you dumping into a septic system for the cabin? I leave my gray valves open until a day before dumping my black tank for flushing the line purposes.
3) Put a thermometer in it and see what temperature you are really getting.
4) Still not understanding concerns about batteries if you have shore power. Since you are living in the trailer, a generator of ocassional use would be the best solution for off grid power.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
CA Traveler
The Western States
Posted: 06/29/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Dave, He posted unreliable shore power.
Super_Dave
Harrisville, UT
Posted: 06/29/20 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Must have missed that. Generator as alternate power source is still my answer if microwave and air conditioning is in play.
Rwake901
Central, Illinois
Posted: 06/29/20 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
It is my understanding that most “wine coolers” only cool down to around 40 degrees. I purchased one for my work and that’s what the instructions said.
humblerb
houston
Posted: 06/29/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with Dave on the gray tanks. When we set up, I open both gray tanks and leave them open. I try to remember to close them the day before we are scheduled to leave. If I forget, I close them and turn on the faucets in the kitchen and bathroom and let them fill before breaking camp.
Just something to flush the drain lines after emptying the black tank.
The reason the shower didn't back up is, they are two separate tanks. That is why you have two drain handles.
You just have to learn the tank levels by experience, because the sensors across the board are extremely unreliable. Be sure not to let the black back up, for obvious reasons.
