RV.Net Open Roads Forum: General RVing Issues: Water heater problem
 > Water heater problem
scottsnider
Lakewood
Posted: 06/28/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new to me 2004 HiLo with a Atwood water heater. Now the WH works on electric just fine but when I try to use gas I get a spark but no flame. So I checked with a gas meeter and there is no gas going to the WH. Can anyone help me to get the gas on or should I get a repairman to do it? [image]
rk911
DuPage County
Posted: 06/28/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
ummm ...is the gas supply on? does the stove light? if yes/yes light the stove and let it burn for about 60-sec and then try the WH.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
corvettekent
Marysville, WA
Posted: 06/28/20 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
If want rk911 says does not work replace the gas valve on the water heater.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
enblethen
Moses Lake, WA
Posted: 06/28/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Atwood gas valves have two 12 volt coils. Disconnect the wire from circuit board, separate the wires at the coils. Use an Ohm meter to check resistance on each coil. the readings should be the same. If not the same replace gas valve.
Check the coil ground wire connection. Located behind gas valve connected via the valve mounting screw.
Use volt meter to check for 12 volts DC coming out of circuit board while the ignitor is sparking. No 12 volts DC means new circuit board. Recommend Dinosaur Electronics version.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Bob/Olallawa
Kitsap Co, WA/Bullhead City AZ
Posted: 06/28/20 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ What Bud said ^^^
Welcome to my home, that door you just broke down was there for your protection not mine.
scottsnider
Lakewood
Posted: 06/28/20 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you Bud, I will be honest with you I have never been able to use a Ohm meter right, one time it got really hot and other times it reads nothing.
enblethen
Moses Lake, WA
Posted: 06/28/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Turn on meter. If it is a digital, it should display OL in resistance mode (Ohms)
When leads are touched together it should read close to Zero. When testing the coils, the meter should read around 25-40 Ohms on each coil. Most digital meters have automatic range.
Voltage test would be done on around a 20 volt DC scale. One lead (black) goes to ground and the red lead would go to circuit board output.
Didn't ask before, Does the ignitor click? This is spark at the water heater end of burner tube.
Which Lakewood are you located?
kellem
Shenandoah valley,VA
Posted: 06/28/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
The few times it happened to me, it was a paper wasp in the orrifice.
I used a coat hanger and dug it out.
old guy
Oregon (pronounced Or e gun)
Posted: 06/28/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
you might try cleaning the electrical terminals before replacing parts. a lot of the time they make poor contact and the heater will not work
Wherever I happen to park
Posted: 06/29/20 05:26am Link  |  Quote  |  Print  |  Notify Moderator
They Do???? (I have and atwood)
And on teh Dinosaur board recommendation.. SECOND.
Suspects in order
Out of gas (Stove won't light)
Tank(s) shut off (Stove wont't light)
Bad regulator (Stove may light or not but all burners at once likely not).
Pinched gas line (Visual inspect)
Bad valve
Bad control valve
Clogged orifice (A spider likes to nest in 'em clean and try again)
Home is where I park it.
