RV.Net Open Roads Forum: Should I connect my sewer line when camping?
 > Should I connect my sewer line when camping?
old guy
Oregon (pronounced Or e gun)
Posted: 06/28/20 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
another good reason is it's is just one step you don't have to do when you already have a long list of things that more important to do when setting up camp
SDcampowneroperator
South Dakota
Posted: 06/28/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
by all means for conservation and to reduce buildup of the dreaded Poo Pyramid it is best to allow your black tank to fill to capacity before dumping. Enough water must be used to do a flush.
In regularly below freezing weather this is not an option waste Tank valves must be left open so no 'trap' and sufficient water used ( flush twice) to move the waste. This works in warm weather also but does ise extra water and take education particularly of the younger folks.. In any case enough water must be used to make the solids more fluid.
The old saying is valid, ' flush twice, its a long way to the kitchen'
Flan
NE
Posted: 06/29/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
When I get to the campground I fill the black tank halfway. use it till it reaches 3/4 and then dump and start over. usually the hose is always hooked up. I have a separate valve for my grey water and usually let those get to 3/4 as well and empty those after dumping the black tank.
Heartland Prowler 27LX
19 Ram CTD 2500
Wherever I happen to park
Posted: 06/29/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
How I do it.. NOTE I can normally go about 3 weeks without taking on water or dumping. sometimes 4 or 5.
Summertimes I spend 2 weeks where I am now hooked to electricity only
And two weeks in another park .. I hook up dump and fill shortly after I arrive and the day before I leave (usually) Dump-refill and stow the hoses..
Half the work of hooking up at every site.
Home is where I park it.
pitch
NY
Posted: 06/29/20 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I hook it up on arrival. Whether overnite or several days. Unless I am a a particular destination the only reason I am in a RV park to begin with is to catch up on services.
mgirardo
Brunswick, GA
Posted: 06/29/20 08:03am Link  |  Quote  |  Print  |  Notify Moderator
It's really a personal choice, whatever works best for you. If we are camping more than one overnight, we'd hook up sewer at the same time as water and electric. If we were just doing a quick overnight and didn't expect to fill the tanks, then we would not hook up sewer.
There is no right or wrong way. For me, I like to get all the hookup out of the way at the same time. If we get setup and need to leave quickly, then I might skip the sewer connection, but that's unusual. Other than animals possibly getting at it (which I've never had happen or know anyone that it has happened to), there is no harm in hooking up the sewer hose when you first setup.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Mickeyfan0805
SE Wisconsin
Posted: 06/29/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I have a similar approach. We are a family of 5 that does all showering, dish cleaning, bathroom usage, etc. in the camper. So, we really can't get more than a few nights without needing to dump. For a weekend trip, I might do it upon arrival if I have time and nice weather, or I might wait until departure if circumstances demand. Longer stays, I always set up at the outset so that I can dump as needed.
Dick_B
Palos Heights, IL USA
Posted: 06/29/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
One advantage to waiting to hook up is if your stay is not long enough to require dumping you have eliminated one nasty job.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
kellem
Shenandoah valley,VA
Posted: 06/29/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
If I have full hook-ups I'm certainly taking advantage.
By all means, go ahead and attach sewer hose on arrival if you want.
The only thing that really has any significance regarding your black tank is never let it go dry.
When it's full, pull the valve and empty.
Once it's empty, add a few gallons of water and treatment....it's really that simple.
Lantley
Ellicott City, Maryland
Posted: 06/29/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
For the most part . I set up right away to get it over with. If its a short stay that I don't need to dump obviously I won't set it up.
If weather is bad on arrival I may wait for better conditions.
Sooner or later it needs to be done so I generally just get it over with when I arrive
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
