RV.Net Open Roads Forum: Fifth-Wheels: 2000 Komfort 5th Wheel
 > 2000 Komfort 5th Wheel
gmoggy
Rouge River, OR
Posted: 06/28/20 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
Wondering where the manual crank connection for the slide room is located.
The previous owner told us that he had an issue with a broken "pin" in the slide room mechanism - Anyone have any info regarding this.
Thanks
RobWNY
Jamestown, NY
Posted: 06/28/20 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
There's usually a hole on the opposite side of the trailer directly across from the slide out. If there is no hole to put the manual crank in to, check underneath that same area for a nut that the crank fits on to to turn.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
