RV.Net Open Roads Forum: Tech Issues: Generator Sound/fire box
 > Generator Sound/fire box
imjustdave
Posted: 06/28/20 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Installing a onan generator in a 5th wheel. My 5th wheel came without the fire bax - sound box, to make matters worse the local dealer isn't very helpful in getting the factory one. More like drama about it.
The other issue is I haven't been able to find a unit with a genst in it so i'm not entirely sure what all this box does - is.
Anyways hoping others could maybe send photos and tell me what they have in their trailers.
Just for clarity the ONAN is going in, that choice has already been mad and won't change. Other advice for portable, honda ETC isn't needed in this topic please, that isn't what this topic is about.
* This post was edited 06/30/20 10:47am by imjustdave *
David
Jayco 2007 30.5 BHS ... Not sure I need the bunks now.
Dodge 2006 3500, Manual, free spin, B&W hitch.
Wherever I happen to park
Posted: 06/29/20 05:18am Link  |  Quote  |  Print  |  Notify Moderator
The easiest way is to use a portable.. Or two
Honda, Yamama and several other INVERTER generators you can get optional Parallel Kits. two Honda 2000i's (The i means inverter) give you a full 30 amps with the parallel kit or a 2000i and a 200i-companion (the companion is more expensive but the parallel kit is cheaper as part of it is built into the Companion) You can also use them independent.
Honda's have the optional extended run tank as well Far as I know they are the only ones that have that feature.
You can store 'em anywhere you can store 'em Just be sure to lock them down both in use and storage so they don't grow legs and walk off,
Home is where I park it.
jjrbus
FT Myers FL
Posted: 06/29/20 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Different strokes for different folks. If someone gave me an Onan I would sell it. Others do not mind the expense or owning one. Box's for the gensets vary a bit but are basically a metal lined box.
Soundproofing is not a consideration in the RV industry, until getting up in the high end coach's. The older Onans are horribly noisy and because the way they are added to the RV are difficult to quiet down. The new ones may be quieter?? but unlikely, as the only online statement I see is the new LP ones are 15% quieter than a diesel generator.
You tube and the web will be your friend on this, there is lots of videos and info. Here is a sample. I use a window AC and a Honda 2000, not for everybody.
https://www.youtube.com/watch?v=s39PJtgZ7HA
Lantley
Ellicott City, Maryland
Posted: 06/29/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I don't think you understand on board gensets. They are all about convenient power. There are no gas cans to deal with. There is no set up. No cables. No storage or security issues. No carrying or handling.
No walking off.
There is just push button convenience. Want power just press a button and you can run both A/C units or anything else.
Yes you pay for that convenience,however with a on board genset your RV is ALWAYS self contained.
@ the OP my suggestion is contact a genset specialist or service company instead of an RV dealer.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
midnightsadie
ohio
Posted: 06/29/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
X2 but in my shop is a generac rv gen set, in a box 30amp like new less than 5hrs, inlaw was redoing a rv and bought this died before install. if you have interest pm me or send a text # I, send pics , one nice self contained unit.
bobsallyh
Livingston, TX.
Posted: 06/29/20 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
When I put an Onan in our fiver, that wasn't generator prepped here is what I did. First of all I'm glad it wasn't prepped. Later saw some of the same make fivers prepped, no thanks. I measured for the "firebox", and layed out what I wanted, then took the layout to a Sheetmetal shop. He did what I wanted, there were several pieces, sides and top. I brought it home and installed it. Has worked well for 17 years. Wasn't a hard job at all if you are handy.
MrWizard
Traveling
Posted: 06/30/20 12:10am Link  |  Quote  |  Print  |  Notify Moderator
The boxes? I have seen in my RVs, all class A's
One Genirac the rest Onan were not for noise
They provided heat/ protection for the RV from the generator, they also provided some measure of road grime protection, all had two openings on the bottom, fresh air in for cooling, hot engine fan air out
As long as your box does that, that are good
Radiate The Happy
1997 F53 Bounder 36s
dougrainer
Carrolton, Texas
Posted: 06/30/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
YEARS ago when most Class C's had no Genset's we installed Gensets and had to build the box and insulate it and make it air tight to the Inside. You build a box in a RV to make it slightly less loud inside and to seal it from the inside. Look at the link I provided. This type material is usually available locally in 4 by 8 foot sheets. It has a foil back and you install with the foil visible. You cut and install on the sides and back and ceiling using liquid nails. If you have no box make one out of 3/8 plywood and then install that insulation. Once the Insulation is glued in you then use rubber silicone to seal all the edges to make it air tight. Most RV Gensets are vented thru the floors now and require no vented door. BUT, I would vent the door if on a 5th wheel or trailer. More air is good. Doug
imjustdave
Posted: 06/30/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Doug, But I think we missed your link?
imjustdave
Posted: 06/30/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Easier then pressing a button on the wall?
I appreciate the suggestions but this topic is about that box. The decision of what system to go with has been made, right or wrong it has been made.
