RV.Net Open Roads Forum: Tech Issues: shower head
 > shower head
huskyfan68
usa
Posted: 06/29/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 Wildwood travel trailer and the shower head is junk. I am going to order a new one (it's connected with a hose into faucet)- Are these all universal size? Also - any advice on keeping squirrels from eating my propane hose?
ajriding
st clair
Posted: 06/29/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
yes, typically are universal, your home kitchen sink hose should be the same also.
Boomerweps
Hills of PA
Posted: 06/29/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Oxygenics is the brand everyone, including me, recommends. It provides a higher flow pressure and has a built in pressure relief center hole to maintain temperature when otherwise shut off with the flow button on the nozzle.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
Fisherman
Angus, Ontario, Canada
Posted: 06/29/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Although cost prohibitive they do make this and if you google metal hose loom you might find something more palatable for the wallet. https://www.cabletiesandmore.ca/flexo-stainless-steel-sleeving
Wherever I happen to park
Posted: 06/29/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Standard size is 1/2 inch straight thread with washer or 1/2 inch IPT (Iron Pipe Thread) I don't know of anyone who makes one different.
Like someone said Kitchen takes standard fittings too
Only reason I got a bathroom fitting at an RV store was they had the style I wanted the Hardware did not.
Oxygenics is also my brand of choice.
Home is where I park it.
SpeakEasy
Western New York
Posted: 06/29/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
If the showerhead you buy doesn't have its own shutoff valve, I recommend this one.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
brianosaur
Long Island
Posted: 06/29/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto.
And squirrels eating propane hoses? Really?
Did you lube them with peanut butter or something?
Dont they usually just gnaw things to make a nest or a hole to gain access to somewhere.
Wonder why on earth they would eat a hose?
...but anyway, those little buggers can be annoying. Had a family in my shed that took me weeks to trap and release. Spray painted their tails to bc one came back from 1/2 mile away!
What about some flexible plastic wire conduit they use in cars? It usually has a slit down the side to slip over existing cables.
Dusty R
Charlotte Michigan 48813
Posted: 06/29/20 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
My problem has been that our shower head has a valve on it, which I want, but they drizzle, when closed, which allows the hose to fill with cold water.
What I have done is go to Tractor Supply and in their farm/field sprayer area they have 1/2" National Pipe Tapper, NPT, to threaded Garden Hose fittings. This would be, female pipe to male garden hose, and female garden hose to male pipe.
Take the shower head off the hose, Put the adaptors on the hose and head then put a garden hose valve on the hose then the head on the hose valve.
Now the when you turn the garden hose valve off, it will not drizzle, and the water temperature will hardly change.
mobeewan
Hampton, Va
Posted: 06/29/20 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Rodent resistant sleeves for wiring and hoses. once you use the sleeves you can sprinkle the weave with powdered Cayenne pepper for extra protection.
You might try antiratpro. It is a Cayenne pepper based spray. A couple of the nomads with YouTube channels swear by it. One of them had mice that keep getting into his engine compartment and inside his dash.
Mice, squirrels and most other rodents are affected by the spiciness of hot pepper extracts. They sell bird seed that has pepper in it to keep the squirrels from eating it. The hot spiciness does not affect birds. They can't taste it.
You might also just try using some Tabasco sauce or pepper sauce with a high Scoville rating and rub it directly on the hoses.
* This post was edited 06/29/20 08:08pm by mobeewan *
2 Retired
Montross, Virginia
Posted: 06/30/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Oxygenics X5 So much more water pressure and so much less water used! we have used electrical tape wrapped around our propane hoses. Seems to help.
Two young retirees restless to GO!
Life is too short to wait too long to do all we want to do!!
Go and enjoy!!
 > shower head
