RV.Net Open Roads Forum: Tech Issues: shower head
 > shower head
JimK-NY
NY
Posted: 06/30/20 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Oxygenics might be a good shower head if you are hooked up or have ready access to water. If you boondock and need to conserve water it is not a good choice as it normally operates at about 1 gallon/minute. One gallon is the total amount of water I typically use for a shower.
AllegroD
Outdare
Posted: 06/30/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Oxygenics works for us full hook up or boondocking.
Ron3rd
Upland, CA USA
Posted: 07/01/20 08:10am Link  |  Quote  |  Print  |  Notify Moderator
2 Retired wrote:
Oxygenics X5 So much more water pressure and so much less water used! we have used electrical tape wrapped around our propane hoses. Seems to help.
X6 and they now come with a shutoff button
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Wherever I happen to park
Posted: 01/10/21 04:43am Link  |  Quote  |  Print  |  Notify Moderator
Every shower head I've seen. EVERY ONE was the same size thread
Suggest oxygeneics Camping world has a few very nice ones. Mine is the Body Spa
Home is where I park it.
AllegroD
Outdare
Posted: 01/10/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Also like Oxygenics. We have the Fury. Works great.
Sjm9911
New Jersey
Posted: 01/10/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
They sell stainless wraped hoses. They ate mine also. I think they like the rubber. There known to eat through wires in attics also.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Posted: 01/10/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
brianosaur wrote:
And squirrels eating propane hoses? Really?
Turns out they find those hoses quite tasty.
Less someone "lubs" them with something like Tobasco Sauce.
dougrainer
Carrolton, Texas
Posted: 01/11/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Dusty R wrote:
My problem has been that our shower head has a valve on it, which I want, but they drizzle, when closed, which allows the hose to fill with cold water.
What I have done is go to Tractor Supply and in their farm/field sprayer area they have 1/2" National Pipe Tapper, NPT, to threaded Garden Hose fittings. This would be, female pipe to male garden hose, and female garden hose to male pipe.
Take the shower head off the hose, Put the adaptors on the hose and head then put a garden hose valve on the hose then the head on the hose valve.
Now the when you turn the garden hose valve off, it will not drizzle, and the water temperature will hardly change.
The REASON RV shower heads drizzle when the OEM shut off is OFF is simple. The HOSE from the faucet to the Shower head is NOT designed for continous 45 plus PSI water pressure. Purchase a metal flexable hose when installing a positive cut off Shower head valve. Doug
Posted: 01/11/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry Doug but that's not it.
I used two shut off valves in my RV and confirmed this
The first was a full shut off, a quarter turn ball valve that I ended up using elsewhere. The problem is if you went FULL OFF then when you turned it back on (Depending on several things) you either got a blast of COLD or SUPER HOT water (120)
The "Shower cut off" dribbled. and thus did not do that. and that's why they dribble
The hose is designed to take 40-50-60-78-80 Likely 100 PSI or more for a long long time.
dougrainer
Carrolton, Texas
Posted: 01/11/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
You know, You have NO IDEA and NO EXPERTISE, but you have constantly posted. I KNOW what I am talking about. I have 41 years of dealing with this type problem and have had numerous customers that used a positive cut off and have had the hose burst. Doug
 > shower head
