RV.Net Open Roads Forum: Class A Motorhomes: Opinion: 1991 Fleetwood Southwind 30'
 > Opinion: 1991 Fleetwood Southwind 30'
IAMICHABOD
Sunny So Cal 90713
Posted: 06/29/20 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
If that 2014 Coachmen Freelander 21' is built on a Chevy Chassis as many were that would be a good choice.
If the price is right and condition is good it may worth looking into.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
A Good Cigar
Avondale, AZ
Posted: 06/29/20 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
rhudson1111 wrote:
Thank you all for your feedback...It's a MAJOR help to me! I am going to take a look at this one tomorrow and see how it goes. On another note, I just found this today: 2014 Coachmen Freelander 21' for a huge discount. It's smaller than wanted, but I've need to consider the age. The reason I talked about a gas generator previously on a larger rig was, that someone mentioned that if I'm going to live aboard or spend a lot of time on it, that a gas generator wouuld be needed for ongoing power of all appliances for multiple days. I'm learning as I go. If the majority agree not needed, I'm happy not to spend money on it [emoticon] Thanks!
DO NOT EVEN consider buying a motorhome with the onboard generator removed!!! That is one of the worst decisions a new RV'er can make. The whole point of a motorhome is that it's "self contained", it needs nothing else when properly equipped to live in it for days at a time. And what if your dash A/C isn't working or is inadequate to cool the entire RV? A lot of motorhome owners drive with the generator running & use the rooftop A/C for more cooling, especially if you have multiple passengers in the back or pets! Trailers and most fifth-wheels don't have onboard generators, and even those that do (upper-end fifth wheels & toy haulers) can't move without a tow vehicle.
If the motorhome is missing the generator, you have to ask yourself; what ELSE is is wrong or missing?!
I'm sorry if I'm coming off as an alarmist, but 99.5% of motorhomes since the late '80s came with generators.
Happy hunting
2000 Itasca Suncruiser 35U
Dale.Traveling
Newport News, VA
Posted: 06/30/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
rhudson1111 wrote:
,,, The reason I talked about a gas generator previously on a larger rig was, that someone mentioned that if I'm going to live aboard or spend a lot of time on it, that a gas generator would be needed for ongoing power of all appliances for multiple days. I'm learning as I go. If the majority agree not needed, I'm happy not to spend money on it [emoticon] Thanks!
The onboard generator should be size to power ALL appliances install when the coach rolled off the assembly line. The assembly line part is important as an owner installed second A/C might be too much for the generator with the original A/C also running. You should have the owner bring the generator on line and run the coach roof A/C and anything else you can easily turn on to try and load the generator as much as possible but staying within its designed limits.
As mentioned it would be unusual for a class A not to have a generator plus your description of the coach included "refurbished generator".
2006 Hurricane 31D built on a 2006 Ford F53
tom28
Tampa
Posted: 07/02/20 02:39am Link  |  Quote  |  Print  |  Notify Moderator
As was mentioned there is no need to buy second generator. However, I'm the age of your motorhome. I don't trust the old ones. Look through fleetwood reviews
enblethen
Moses Lake, WA
Posted: 07/02/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
The "Fleetwood Reviews" are for the current Fleetwood and not the one from 1991.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
