RV.Net Open Roads Forum: Travel Trailers: Crack in Black Tank
 > Crack in Black Tank
atrerice
Michigan
Posted: 06/29/20 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Last season we discovered a small crack in our black tank, which I repaired with PlastiMend. It stopped the leak and I thought it was going to be a permanent fix. Until a week ago when I de-winterized it. I noticed another crack in the area that was repaired and was dripping. I'm looking at different ways of repairing - Looks like some people have had success with G-Flex 655-8 Epoxy and fiberglass mesh. Another thing I was looking at was PC-7 Epoxy which I have had experience with fixing many things with a lot of success. Does anyone have any recommendations on repairing this crack?
Thanks in advance!
Art
BobsYourUncle
Calgary Alberta Canada
Posted: 06/29/20 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
I had a fairly large crack in one of mine a few years ago. Noticed stuff dripping underneath....
I was on the road and didn't want to drop the tank, get it fixed and all that. Busy working, no time. I'll fix it properly when I get home.
Being in construction, I always have a great selection of building supplies in my truck tool boxes, including a roll of Bakor Blueskin. This is a peel and stick waterproof membrane used in construction for making things watertight. An extremely sticky tar like adhesive on one side, a smooth flexible 100% waterproof surface on the other. This stuff sticks very firmly to virtually any surface.
I emptied my black tank, then jacked up my TT on the side where the crack was, so any remaining waste in the tank went to the other side. I used some fine sandpaper, thoroughly cleaned the area around the crack, and then liberally wet a rag with acetone and washed the area.
Then I cut a piece of the Blueskin, pulled the backing off and carefully covered the crack, with several inches of the membrane extending past the crack in all directions, thoroughly putting pressure on it to completely stick to the tank.
For good measure, I got out my heat gun (substitute hair dryer here), and got the patch good and warm all over, further working it to the tank with my hand.
My temporary fix until I got home worked so well, that it was still there when I sold my TT about 4 years later. It sealed 100% and never leaked again.
My crack was right close to the dump pipe.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
atrerice
Michigan
Posted: 06/29/20 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
That's exactly where the crack is on my tank - right near the dump pipe. Now that you mention it, I wonder if a piece of Eternabond tape would seal it. I've had really good results on the roof and it sounds similar to the tape you describe. One thing I've done on the roof is apply Lexel caulk at the seams of the tape so there would be no chance of it peeling up.
time2roll
Posted: 06/29/20 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming it is black ABS tank I can't imagine anything is better than plasti-mend. Must be some kind of stress point to make it crack again. My leak was at a corner stress point and I used some sheet ABS to strengthen the repair. Holding about ten years now. Good luck with the epoxy or tape.
675w Solar pictures back up
atrerice
Michigan
Posted: 06/29/20 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
That's right a this is a black ABS tank
I do see that Plastimend has a kit that comes with some sheets of ABS. Is that similar to what you did? The spot I will be repairing is right under where the dump pipe connects to the tank.
Guy Roan
Posted: 06/30/20 04:24am Link  |  Quote  |  Print  |  Notify Moderator
I would go with the West Systems "G-Flex epoxy" if it was mine.
I work with it a lot on repairing plastic, fiberglasss and carbon fiber canoes and kayaks.
It was one of the few epoxies that is made for plastic.
Give West Systems a call and they will walk you through the process
Guy
wtmtnhiker
New Hampshire
Posted: 06/30/20 05:37am Link  |  Quote  |  Print  |  Notify Moderator
I did about the same as BobsYourUncle as far as tipping the rv etc but I repaired mine with epoxy . I dug the crack out a little so I could get more epoxy into it and it held for a number of years until I traded it in. The surface has to be very clean and dry and I left the epoxy cure for a couple of days with the trailer tipped to the side. Good luck.
bgbassman(bluegrass bass man)
time2roll
Posted: 06/30/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the sheet was extra from Plasti-Mend. I cut the sheet then used a heat gun to get the curved shape just right before making the repair. All corners rounded etc. Used lots of the adhesive and had a jack ready to gently hold in place. Need to work pretty fast to get it set just right. Next day slathered more on top and especially around the edges of the ABS patch to have everything smooth and stress free.
atrerice
Michigan
Posted: 06/30/20 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
I'm leaning towards the GFlex epoxy since the first repair I made was with the PlastiMend. Now, that was not with an ABS sheet though. If I use the GFlex, I would embed some fiberglass mesh in it.
Drew A.
Massachusetts
Posted: 07/01/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I used Plastimend with fiberglass screening on a crack right at the dump pipe outlet and built up the ABS thickness in this area. It has held for several years and I inspect it yearly. No cracks at all.
Did yo use mesh with the Plastimend? I think that using mesh is pretty much mandatory.
2018 Ram 3500 CTD, 4X4, Laramie, SRW, SB
2010 Jayco Jayflight G2 32BHDS, ProPride 3P Hitch
