RV.Net Open Roads Forum: Extreme Mold & Water Damage: I need help!
 > Extreme Mold & Water Damage: I need help!
smchristin
Cana, VA
Posted: 06/30/20 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Hello all! My name is Steven and I am working on a friends camper. I'm not sure if it is considered a travel trailer or not so please forgive me!! It is an Eagle by Jayco and I have no idea what year. I have all the manuals but I cannot find anything about a year or model. Anyway I was asked to work on it because it was obvious that water had gotten into the very aft wall where the bathroom is. I pulled the mirror, sink and bathtub out then started to remove insulation. The more I removed the more I became devastated. Literally 80% of the entire back wall is black and crumbling. Since water travels down I started to remove a bit of the floor to see how far down the vertical wood frame goes. Long story short, the point I am at right now is trying to figure out how I will replace the wood structure, especially since the vertical wood pieces go down beyond the floor and beyond what appears to be the metal base. I have no idea how or where to secure the wood structure. Please Please Please give any kind advice. Thank you.
The only way I could figure out to get a bunch of pics is to put the link to an album in my Facebook. Just copy and paste this URL.
https://www.facebook.com/media/set?set=a.10157998926811998&type=3
blownstang01
Upstate NY
Posted: 06/30/20 04:18am Link  |  Quote  |  Print  |  Notify Moderator
I hate to say it, but this one is toast and time to move on. From your pictures I can see a bunch of delamination in the fiberglass on the front of the trailer too. So the front is just as bad if not worse than the rear. Once water damage gets this bad they simply are not worth the time and money to fix. Been there, done that. You'll have a ton of time and money into a band-aid fixed trailer that's worth maybe a couple grand. Time for your friend to sell as a hunting cabin. Good Luck !
BurbMan
Islip, Long Island
Posted: 06/30/20 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Hi Steven, welcome to the forum! Most folks don't know that RV manufacturers recommend that you check all of the roof and window seals at least 2x per year. It's not uncommon for the caulk to crack and let water seep in, and after a few years, a tiny leak causes what you see here.
These campers are not hard to fix from a materials and skills standpoint, but it has to be a labor of love because it never makes economic sense. As blownstang01 points out, you can see in the pics that the fiberglas is all wavy in front of the front bedroom window indicating the same kind of damage that you are dealing with in the rear bath.
These campers are built from the outside in, so you're looking at taking off the exterior fiberglas and sheathing, replacing the framing, and rebuilding the back wall, part of the floor, and some of the sidewall. Basically keep cutting until all the old wet moldy wood is gone and then rebuild. This also means dealing the with electric and plumbing that runs through the framing, in one pic I see both 12v and 120v running in the back wall.
Add in what's happening up front and you will have hundreds of hours into this project. Only you can decide if it's worth it.
If you look on the A-frame of the trailer tongue, up front by the propane bottles, you should see the 17-digit VIN stamped there somewhere. If you get the VIN and call Jayco customer service, they should be able to give you all the particulars about the trailer.
The trailer looks like it's about 10-15 years old, and bear in mind that appliances like the fridge have an expected lifespan in that range. If you do a web search you will find many projects like yours, I myself am in the middle of rebuilding a slide-in truck camper with extensive water damage. We are happy to help you through the process, but know what you're signing up for...
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Under renovations:
SOLD: 2001 K2500 Suburban LT 8.1L/4.10
2008 Terry 34' TT many mods, Hensley Hitch
valhalla360
No paticular place.
Posted: 06/30/20 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Going off the pictures, I would be looking at about $3k if it was in good condition.
By the time you chase down all the rot, it will have an entirely new outer shell and lots of the interior and floor redone. If you do a lousy job, it won't even be worth $3k.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Posted: 06/30/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Honestly a trip to the dump or a couple gallons of gas and a match are the 2 best solutions here.
midnightsadie
ohio
Posted: 06/30/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
show these post to the owner, so they don,t think your backing out. sad but its toast , repair cost way more than the rv is worth.
smchristin
Cana, VA
Posted: 06/30/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the feedback. Yea I know its toast and not worth it to some. I'm not afraid to try tho. I'm not gonna dump a lot of money into it but I wanna give it a shot. I'm an aircraft mechanic by trade and love learning how to fix things. I will keep posting pics and vids as I go, asking for more input. From here I'm just gonna clean out the last bit of insulation and the delaminated wall board. Then try to figure out how to secure the wall frame pieces. One thing at a time.
Jebby14
Windsor Ontario
Posted: 06/30/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Not much help on the fixing the rotten camper front but i can offer this to post photos here
clicky
2012Coleman
Posted: 06/30/20 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Good to see that you don't let the crab-apples spoil your resolve. Use this link to post pictures: http://photoposting.is-great.net/?i=1
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
CavemanCharlie
Storden,MN
Posted: 06/30/20 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. Sorry I can offer no advice. Except, Just dig in and do the best you can.
