RV.Net Open Roads Forum: Tech Issues: Super Noisy A/C
 > Super Noisy A/C
Gulfcoast
Alabama
Posted: 06/30/20 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I must have one of the most noisy A/C's around....
Two year old Dometic rooftop
It's all air noise.... no vibration.
85 Db at 4 feet.
You can download a decibel meter app and check yours too.
Let us know what brand a/c you have and the actual sound reading.
Think I want a whisper quiet mini-split.
* This post was edited 06/30/20 08:19am by Gulfcoast *
Ed_Gee
Central Oregon coast
Posted: 06/30/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Watch this video done by Fit RV: Coleman Mach 10 NDQ
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
bob213
Fresno, CA
Posted: 06/30/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking of trying one of these:
Wacko Products
RobWNY
Jamestown, NY
Posted: 06/30/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I had a Dometic in our old rig. It was so loud I couldn't watch TV without the volume being all the way up. We have two Coleman Mach units in our current rig and they are much much quieter. Whisper quiet is the way to go but the Coleman's aren't bad at all.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Gulfcoast
Alabama
Posted: 06/30/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
With this two year old Dometic, I can't hear anything inside or outside. TV, wife, thunder.
I wish I could play the sound on here.
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 06/30/20 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Check these out.
I built my own silencers and ran them for several years. These have nice filters and look even better than mine. Pricey but sure are well thought out and built.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
1320Fastback
Vista, Ca
Posted: 06/30/20 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have a AtWood AirCommand and it is easily 50% quieter than the Dometic it replaced. It is much colder, throws air much further and also uses less power.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Gulfcoast
Alabama
Posted: 07/01/20 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I won't pay $200 for a plastic kit, I will make my own. Secondly, I will install a mini-split next fall.... they are whisper quiet.
jjrbus
FT Myers FL
Posted: 07/01/20 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I detest roof air and Onan generators. I use a Honda 2000 and an 8000 btu window ac. I went out and checked around 45 db on low. The db measurement does not measure tone some sounds are much worse than others. Think scratching nails on a chalkboard. I have 3 minis in my house and if I had room for the evaporator in my little Toyota would have put one in there a long time ago!
They duct the cooling air in some RV's, ok good. Then leave a hole in the roof to where the fan and blower motor are, well duh!! Might as well sit the unit on the kitchen table! Very simple fix, duct the return air with baffles.
I am sure some are reading this thinking well whats the big deal? Some are more sensitive to noise than others is the big deal.
 > Super Noisy A/C
