RV.Net Open Roads Forum: Class C Motorhomes: Hood Cover for Ford E450
 > Hood Cover for Ford E450
hanknjoyce
Custer, SD
Posted: 07/01/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Dusty - Good to know that some dings disappeared. We had an E350 Class C from 1992-2003 but never experienced hail (lived in Maryland). Had a 42' DP from 2004-2019 but it had a flat front so no dings. But most of the stuff on the roof of the DP was damaged 7 years ago during a once-in-a-generation hail storm here.
Regular covers do not work where we live - a mile high, lots of UV and wind plus strong storms.
I will watch the existing dings for "improvement" but will be covering the hood ASAP.
Hank
Custer, SD
CharlesinGA
South of Atlanta, Georgia
Posted: 07/02/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Harbor Freight has moving quilts cheap, good to have several on hand. Also good to pad an area where you are working on something.
Charles
Need a new owner for my 2007 Winnebago View 523H on a '06 Sprinter 3500 chassis. 30k+ mi, Prog Ind HW30C, Prog Dymanics PD4645, Chill Grille, deep alum trans pan, Roadmaster sway bar.
Replaced by a '08 Thor FS180 travel trailer and 2003 Ram 2500 CTD 6 spd
hanknjoyce
Custer, SD
Posted: 07/02/20 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Just got two large squares of "mag vinyl" from my local print shop. They stick to the hood like glue..no tiedowns. I will only put them on when we are expecting bad weather. Cover virtually the whole hood. Not super cheap but easy on/off and I can put in the car to use as well when out and about.
